CR gauge cluster in ap1
I had an AP2 cluster swapped into my AP1. it was a pain. Harness is different and correct, the mileage is stored on the cluster. you will have an issue if you are going to 9K as the cluster will start blinking once it is past the 8K limit. Cluster speed may be off by +/-2mph. It is also really hard to find a pin out of the cluster. you may want to purchase an entire AP2 CR dash harness to complete this. I do not know if the other end is the same as an AP1 though. I do have an 04/05 dash harness for sale if you swap to a 04/05 cluster.
I'm going to guess no because they have that green light on the cluster that turns on. And maybe the harness is different because the added wire for that light?
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
what about the miles and other gauges ? Someone told me 06-09 get mileage from ecu is that right ?
