Crappy Head Unit?
Old Aug 4, 2001 | 09:35 PM
tkmak's Avatar
Default Crappy Head Unit?
I just started the audio upgrade on the S2k. Did the speakers first - Sony ES 6.5s.
With the rest of the upgrade coming later, I figured, I could see just how bad the head unit was....
Has anybody noticed the tweeters on the passenger side are signficiantly muted compared to the driver's? Figuring it was faulty speakers, I switched them... Still the same. Tested the speakers on another S2k - Still the same. What the Hell did Honda give us?
Anybody else experienced this?
TKMak
Old Aug 4, 2001 | 10:16 PM
Pinky's Avatar
Honda gave is a great Sports car............not a great stereo system car! Yes its crap to start with. I for one know this best! My stereo will move from 4 speakers and 2 shakers to 4 speakers two shakers to a additional 10 or 12" sub!(soon!)
Old Aug 5, 2001 | 02:09 PM
Utah S2K's Avatar
From your description its hard to tell. You may be out of phase (i.e. + and - crossed at the head or speaker). Never heard of an ES 6.5? Is it a 1621 or 1631 in the Explode series? Sounds more like an install problem (phase or short to ground) then a head problem.....although the head unit is hugely weak.
Old Aug 6, 2001 | 07:55 AM
chriso59's Avatar
I have experienced the same problem... the speaker on the passenger side (all stock) does have less highs then the speaker on the drivers side...i have no clue why though...
Old Aug 6, 2001 | 10:51 PM
tkmak's Avatar
utah s2k,
speakers i put in are Sony ES Xplode 6.5s model XS-V1655G. They take nominal power to 50w, peak 200w. looks same as others, its a three way - costs about $175 or thereabouts from places like crutchfield. mounting depth wasn't too much of a problem since I made new baskets, using the orig baskets as a template. Used 5/16 hardboard - worked out well. I was worried that since the mid/tweeter tower extruded out futher than the woofer level whereby it would not fit under the door panel.
Nice speakers - had an identical set on another car and they do kick for 6.5s.
i thought of the out of phase possibility also - so I tried it in and out of phase with no improvement on the passenger side. Since my girlfriend also has an S2K (LadyDDS), I tried her stock unit.... Same type of output on the passenger side. A problem I guess I will have to rectify with a new head unit and an amp...
As far as short to ground, the both speakers will not work any one of the leads are shorted... I may be wrong on that one.
tkmak
_____________________
'01 silverstone/black
eld4au6
Sep 19, 2011 04:49 PM
whitepony
Nov 1, 2001 06:36 AM
gene
Oct 19, 2001 07:03 AM
