Dash mount for iPhone 4
Ive been using my iPhone 4 as my media player and gps in my car for a few months now. I used bluetooth A2DPI for playing all audio and phone calls so I only use the cable to charge the phone. finally accepted that I need some kind of mount for it. Im not a fan of windshield mounts or the beanbag ones you throw on the dash. I'm looking for something more "dockable" that can rotate from portrait to landscape orientation. I know modifry makes a dash bracket for the S that could probably work for the mount piece but I'm not sure about what to use for the iPhone mount and if it can attach (and fit so it can rotate) on the dash bracket. For power I figured I'd wire in an iPhone cable through accesory power somehow.
Anyway, I'm sure someone has found a neat solution that's working well. If anyone has ideas please share.
hey, im an avid iphone 4 user like you... i use navigon for my gps needs with a proclip mount.. i highly recommend it. i do not have an s2000 yet but i plan on purchasing one within 3 weeks. i already ordered the modifry bracket. check out proclipusa.com
they have the one i got for 34.99 or the one that also snaps at the top for great horizontal use for 39.99. good luck!
yup i use a pro clip adjustable mount for my EVO share it between two cars
best mount i ever bought
IF you use a case for your iphone then you'll need the adjustable mount
http://www.proclipusa.com/brodit-device-ho...1165-18229.aspx
sena ultraslim is all i need and i wont change that for any new iphones
Originally Posted by bmms8,Nov 14 2010, 05:24 AM
i hope none of you use a case with your iphone 4
This is the Droid mount. I don't recall if someone has posted photos of the iPhone 4 mount but it would be in this subforum.
The Modifry bracket is thin flexible steel and does flex a bit under the weight of the Droid. However, I think Modifry updated his bracket design to make it a bit more rigid since I purchased mine.
ProClip does make a vehicle mount for the S2000 but I wouldn't recommend it. It mounts to the left of the shifter and it's possible for your knee to bump the mount.
Panavise's bracket is very secure and solid but mounts directly to the right of the radio.
Arkon IPM514
I just bought this case from amazon it holds the phone extremely tight and is easy to get the phone in and out of it with/without a case...
I bought it because you can adjust the phone position to use the camera to take video.
Originally Posted by kevos2k,Nov 16 2010, 11:45 AM
Arkon IPM514
ill take another look at it when i get home today... im sure you could use some sort of double sided tape on part of it to work fine I dont think it came with a specific flat surface mount tho...
I am using it with the windsheild suction cup
