DEI Hornet 727t wiring
Old Jan 8, 2006 | 08:01 AM
ji3000's Avatar
Default DEI Hornet 727t wiring
Hi all. Question regarding 727t unit:
What is the relay that is attached to the orange (H1/1) and yellow (H1/9) wires from the main harness? Specifically, what are the three inputs, green, black, yellow wires to the relay?
Thanks!
Old Jan 8, 2006 | 09:38 AM
darkknight1999's Avatar
It should be the starter kill circuit. Its the wiring that breaks the start lead.
Old Jan 8, 2006 | 10:05 AM
ji3000's Avatar
two part question:
1.
does the car comes equipped with a factory starter kill? (i'm thinking it does - thats the whole point of the chip inside the key). if so, wlaurent's diagram omits the orange wire including the use of the starter kill relay.
2.
if i need to wire the starter kill relay, where would the two wires from the relay hook up to - black and green wires.
so far, wlaurent's installation diagram has been really helpful. its just that many "features" are not hooked up and he says not supported in the factory harness. This might be very true but I am wondering if anyone has been able to rewire it or simulate the events using any tricks.
Excerpt from his install guide (thanks wlaurent for the diagram):
"The Following is a list of wires on the 700T that are not used and not present on your harness:
Harness 1
chefs2000
Feb 1, 2016 05:06 PM
chViETnk
May 23, 2009 09:05 AM
devilchrist
Oct 24, 2008 10:40 AM
01silverstones2k
Aug 22, 2007 06:25 PM
PilotChris
Jan 1, 2003 07:45 AM
