drilling firewall
Old Mar 11, 2007 | 06:48 PM
itsmylittlebrothersbike's Avatar
Originally Posted by darkknight1999,Mar 11 2007, 07:59 PM
You need one of these
I was thinking prophylactic!
Old Mar 11, 2007 | 07:07 PM
hmss2000's Avatar
also, be sure the power wire is fused or the black snake will bite.
Old Mar 12, 2007 | 08:41 AM
Boofster's Avatar
The S has at least 3 holes that I know of. Why couldn't you use one of those like everyone else?
Old Mar 12, 2007 | 09:23 AM
Dave-ROR's Avatar
He never said that his friends car was an S.
However, I've never once found a car that didn't have plenty of avail space in existing grommets.
Old Mar 12, 2007 | 01:26 PM
smurf2k's Avatar
drilling a new hole is not necessary
there are many existing rubber bushing/grommet things in the firewall. just puncture a hole through one and slip the wire through
Old Mar 12, 2007 | 04:04 PM
revhi's Avatar
Depends on what guage wire your running.
Old Mar 12, 2007 | 04:15 PM
ruexp67's Avatar
I put 4ga through an existing grommet in the S2000. I suppose if you used a wire as thick as a baseball bat, you'd have to drill a hole in the firewall, but you might have other problems with that too.
Old Mar 12, 2007 | 04:20 PM
S2000GT's Avatar
member #15462 of the "4ga through existing grommet club" here
Old Mar 13, 2007 | 06:03 PM
modifry's Avatar
Honorary Member
The 2 grommets at the extreme sides of the engine bay (behind battery and brake fluid) just happen to be right in the path of the rain water that runs down the windshield. It's not a problem if you only drive in the rain, but if you park in the rain and have a sloppy hole in the grommet it will leak into your car. Bigtime.
I know someone who had some engine work done and in the process the big grommet for the engine wire harness got torn. After an overnight heavy rain (I think during a near-hurricane) there was an inch of water in the driver's side of the car.
Liquid electrical tape is your friend. (and available at Home Depot).
Old Mar 13, 2007 | 06:24 PM
S2000GT's Avatar
...i dont think the op is coming back...
