drilling firewall
Old Mar 10, 2007 | 02:03 PM
hoangcs's Avatar
Default drilling firewall
i drilled a small hole through the firewall of my friends car to run a amp power wire. was this a bad thing to do? what problems could he run into in the future?
Old Mar 10, 2007 | 02:38 PM
revhi's Avatar
If you used the proper size gromet, it will be fine.
Old Mar 11, 2007 | 01:22 AM
hoangcs's Avatar
whats a gromet?
Old Mar 11, 2007 | 06:00 AM
itsmylittlebrothersbike's Avatar
It is a rubber bushing that does a couple things: First, it provides a buffer so the power cable will not rub on the nice sharp edge you created when you drilled the hole, and it also provides a seal to keep water, bugs etc out of the passenger cabin. If you run the cable through a hole without a gromet, it WILL short out in no time! That cable moves more than you could imagine.
Old Mar 11, 2007 | 07:46 AM
HARDtoTOP's Avatar
the grommets are available at any hardware store worth their salt. Get one propperly sized for both the hole and wire. It should not be loose around the edges (should make a tight seal with firewall hole) and the hole in the grommet itslef should not be overly large compared t the wire so that it makes a decent seal.
Old Mar 11, 2007 | 08:25 AM
NFRs2000NYC's Avatar
Originally Posted by hoangcs,Mar 11 2007, 05:22 AM
whats a gromet?
Ugghhh Ohh.
Old Mar 11, 2007 | 11:31 AM
S2000GT's Avatar
Originally Posted by hoangcs,Mar 11 2007, 04:22 AM
what's a gromet?
classic!
you should always do some research before plugging in the power tools!
Old Mar 11, 2007 | 04:44 PM
ruexp67's Avatar
whats a gromet?
Also, if you had looked at the FAQ you would see that there is already an easy way to get a power wire through the firewall with an exisiting grommeted hole.
Old Mar 11, 2007 | 04:53 PM
darkknight1999's Avatar
Slowly put down the drill and back away...
Old Mar 11, 2007 | 04:59 PM
You need one of these
