Driver window won't go down with top
First let me say that I have already tried the process of going up and down and holding the button. It actually worked for a day or two, but It doesn't work anymore and I can't repeat my success. Is there anything else I can do? The window drops an inch or so when I lower my top. Everytime I depress the roof switch, the window lowers another inch and stops. Any ideas or where to dig or what you test? I have an 00' btw.
Thanks
Thanks
I think Romelo1680 is correct. There is a Service Bulletin that describes this problem and says to change the window regulator. I guess there is a bad ground in the regulator that causes this. No mention of any way to fix the ground issue.
