Driver window won't go down with top
Old Feb 9, 2012 | 06:12 PM
trich101's Avatar
Default Driver window won't go down with top
First let me say that I have already tried the process of going up and down and holding the button. It actually worked for a day or two, but It doesn't work anymore and I can't repeat my success. Is there anything else I can do? The window drops an inch or so when I lower my top. Everytime I depress the roof switch, the window lowers another inch and stops. Any ideas or where to dig or what you test? I have an 00' btw.
Thanks
Old Feb 9, 2012 | 07:44 PM
thielepr's Avatar
It's something about a module that controls the top down/up. The passenger window is wire trough this box and that's why isn't working. I tried to serach but you know the search is not the best.
Old Feb 10, 2012 | 08:12 PM
trich101's Avatar
That definitely gives me a place to start looking. I'll grab the multimeter and start there. Thanks.
Old Mar 7, 2012 | 08:01 AM
romelo1680's Avatar
i had the same problem . you need a new window regulator
Old Mar 7, 2012 | 02:30 PM
trich101's Avatar
I'll try that, thanks
Old Mar 7, 2012 | 04:06 PM
T-Smac's Avatar
If it goes down by the window switch, the convertible top module is the most likely problem. I have a write up on how to test it around here somewhere. Youll need a multimeter. Ill find it in a bit
Old Mar 11, 2012 | 09:40 AM
T-Smac's Avatar
https://www.s2ki.com/s2000/topic/901...#entry21042170
A couple of posts down..
Old Mar 11, 2012 | 12:13 PM
sdosmil77's Avatar
mite b your drivers switch. it does alot. i found it to be the problem in why my pass window wouldnt go down.
Old Jul 31, 2012 | 10:19 AM
jwfs2k's Avatar
I think Romelo1680 is correct. There is a Service Bulletin that describes this problem and says to change the window regulator. I guess there is a bad ground in the regulator that causes this. No mention of any way to fix the ground issue.
Old Sep 19, 2016 | 10:28 PM
Soviet's Avatar
Was this ever resolved? I have the same issue right now.
