DRL indicator light
I've recently noticed that my DRL indicator light comes on under hard braking. I've noticed it a few times at the track applying the brake hard when entering a turn off a high speed straightaway.
The high beam bulbs work fine. The indicator light operates as expected at all other times (comes on at ignition and turns off when parking brake is released).
Possible issues? Battery amps, fuses, relay, or DRL module? Or could it be that the parking brake needs adjusted as somehow it's being activated under hard corner braking therefore activating the DRL light for a split second.
Not sure if anyone has had a similar issue. Need some help troubleshooting.
danny4289
May 31, 2010 10:34 PM
