DRL with LED... Possible?
Old May 15, 2012 | 04:48 PM
s2kJer's Avatar
Default DRL with LED... Possible?
Since our DRL lamps also double as the high beams I was wondering if anyone tried LED lamps in them yet....
If so, do they work?
Sent from my Galaxy Nexus using Tapatalk 2
Old May 16, 2012 | 06:25 PM
600rr's Avatar
If you use led bulbs to replace the high beam they will work. You will just have to deal with the drl light being on. Led bulbs are not bright enough to actually use as high beams.
Old May 23, 2012 | 01:28 PM
s4play's Avatar
There are other issues associated with the LED bulb - it's not a plug/play affair so be warned!
Besides losing your high beam you need some parts to make it work. Best to just unplug and re-wire
Old Aug 13, 2012 | 08:07 PM
sse2k's Avatar
Did you ever end up doing the LED DRL mod?
I was going to do this to my RDX before I sold it. Basically the same setup due to the combo DRL/High beam, but it needs additional circuitry so as to not trip the DRL light on the dash.
http://store.ijdmtoy.com/9005-LED-Da...d_sku45_r2.htm
Old Feb 7, 2013 | 05:03 PM
twinpnoy84's Avatar
Has anyone ever done this?
Saki GT
Mar 22, 2024 12:56 PM
martin j
May 30, 2016 12:45 PM
s2konroids
Jan 12, 2012 12:31 PM
stfutexas
Jul 14, 2009 11:46 PM
LostWaffle
Nov 3, 2004 11:56 AM
