DRL and wiring
Old Dec 7, 2017 | 12:01 PM
adriangb's Avatar
Default DRL and wiring
Hi guys,
I just got a 2007 S2000. I noticed the previous owner (or the one before him) did a DRL delete. When I have the car on and ebrake down, the DRL light goes off which from what I understand means they should be on, but they are not. Highs work just fine. I looked at the fuse box and it seems fuse for DRLs (#14) is missing. I'm going to put that back in and see what happens, but I also noticed there's some wiring just hanging under there: anyone have any idea what these are?
Old Dec 8, 2017 | 06:37 AM
Chuck S's Avatar
The DRLs are the high beams at reduced voltage and controlled by two boxes situated side by side under the dash. For US cars see pages 22-119 thru 22-122 in the 2007 service manual. The Canadian cars only have one module. I don't see a Brown wire in either diagram, though, 14 pin connectors to both boxes so not sure what the smaller connector may be.
-- Chuck
Old Dec 8, 2017 | 07:11 AM
adriangb's Avatar
Thanks. I'll try to get some better pictures today. I only have the 00-03 service manual, which obviously doesn't have any info on this.
Old Dec 8, 2017 | 09:36 AM
Nitroturtle's Avatar
No idea about those connectors, but removing the fuse should be the only thing required for a DRL-delete. I imagine replacing the fuse will make them start working again.
Old Dec 8, 2017 | 08:35 PM
adriangb's Avatar
Took a better picture. The large connector is labeled HWAXE04B 9. Upon searching the net, it seems many cars have this and it's just a connector for optional accessories (i.e. alarm). I couldn't find anything in the 00-03 manual so I can't confirm. I am going to put the fuse back in and see what happens to the DRL, just have to find time to go buy one.
Old Dec 30, 2017 | 08:36 PM
adriangb's Avatar
Update: so those wires are for the stock alarm I believe. The DRL were fixed by putting the correct fuse in, go figure.
Old Jan 17, 2018 | 06:32 PM
JS2k.com's Avatar
Sponsor
Yep, that's what I did for a DRL delete too: remove the fuse.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
cinaibur
Feb 17, 2012 08:13 AM
dbzerk
Jun 13, 2010 09:43 PM
Black Knight
Apr 15, 2009 04:55 PM
Davizzle
Dec 23, 2007 03:26 PM
