electrical problem................
Old Mar 10, 2005 | 11:12 PM
keith_seo's Avatar
Default electrical problem................
so there SHOULD be lighting around the dials, right? since some point, i no longer had lighting around the dials and i even got used to not having it...
so i tried to fix it by myself and tried to lift the panel.... and it won't go back in!! (not to mention that i didn't even get to fix it) it's the trim if you know what i mean....
apologize for the quality of the pic... taken by my phone...
should i just take it to a dealership?
thanks!
Old Mar 11, 2005 | 05:01 AM
NativeHero's Avatar
I would recommend taking it to a dealer. More then likely it could be a fuse problem. If it is more then that it will need to go to a dealer. Wiring is something that should be taken lightly.
Hope that helps
Dewayne
Old Mar 11, 2005 | 06:29 AM
darkknight1999's Avatar
While I would fix that myself if your not sure of exactly what your doing it might be best to run it over to the dealer and let them take a look. Its mostly likely a bulb issue or maybe a fuse but I would suspect the bulb first. How long have you owned the car? Did you buy it new?
Old Mar 11, 2005 | 07:55 AM
SheDrivesIt's Avatar
Originally Posted by darkknight1999,Mar 11 2005, 07:29 AM
Its mostly likely a blub issue or maybe a fuse but I would suspect the blub first.
DK, are you making fun of us chubby people?
Old Mar 11, 2005 | 08:03 AM
hahaha yeah that was good...
Fixed!
Old Mar 12, 2005 | 04:50 AM
Kodokan_4's Avatar
You are supposed to remove the entire gauge console before removing the AC/heater control pod.
As you can see from this pic, there is a (hole for a) retaining screw on the back that must be removed.
I can't see anything in the pic you posted.
You should either take it to a dealer or buy a service manual, so you don't break something.
-Pete
Old Mar 12, 2005 | 05:24 AM
Bass's Avatar
are you guys mad?? a dealer for a blown fuse or bulb - ...
i can see them saying "sure sir we can fix it for ten million dollars...
compliments of DJ Cube
http://briefcase.yahoo.com/bc/djqube21/lst...Control&.view=l
Old Mar 12, 2005 | 09:48 AM
TriaXenginE's Avatar
dude, i had the same exact issue with i took apart my dash. all i did was bang on it and the lights came on again. it happened 2 more times and i did the same thing. after that, i never had the problem.
Shinji2787
Aug 5, 2008 02:04 PM
GazS2000
Jan 16, 2008 09:19 PM
Mannn
Oct 10, 2003 10:44 PM
eddie623
Mar 17, 2002 07:15 PM
Andre
Mar 27, 2001 08:03 PM
