Electro luminescent alarm indicator
Old May 15, 2013 | 05:03 PM
MrKlean187's Avatar
Default Electro luminescent alarm indicator
Does anyone else run the newer EL alarm indicator lights instead of drilling a hole for the led's? They are wayyyy brighter and bigger! Maybe too much! What is everyone's thoughts on these?
EL indicator vs standard led
"Electro-luminescent technology for everyday uses. Extreme low current draw, and high visibility, bright blinking panel for security systems. 12 Volt. Price is per each.
Now there's 5 name Brands to choose from, including: Viper, Hornet, Clifford, Python
or Directed.
Flashing Electro-luminescent LED indicating your vehicle is protected by an Alarm system. This can be used with or without a full alarm system installed. It features only a 2 wire installation and has its own built-in transformer. This piece glows in an Aqua Blue color and flashes at approximately 1 flash per second at
a steady rate.
It can be hooked up two different ways. You may connect the black wire to the ignition of the vehicle and the red wire to constant 12V power to cause it to flash anytime the vehicle is off. Or simply change the connection so that the Black is hooked into your starter kill or ground when armed output on your alarm system . It draws an extremely low amount of power.
This 620 will fit and work with any vehicle. It will also work on any alarm system currently
on the market and can be installed without an alarm system at all. This piece is approximately 1 3/4" square and only 1/8" thick.
It has approximately 5 ft of wiring included and has a small transformer in line on the wiring . This will last much longer than Neon. and can be seen from almost a mile away at night!"
Old May 15, 2013 | 08:38 PM
icantbeseen1's Avatar
was that on the vehicle or just a comparison?
Old May 15, 2013 | 09:33 PM
MrKlean187's Avatar
Its on an S in a pitch black garage! I took that video as all the torrential downpours were happening outside. So far 6 ppl have been reported dead due to tornados/severe weather...Thankfully I live a little further north of the tornados and disaster zone!
Old May 21, 2013 | 06:23 PM
iDashX's Avatar
i wouldn't want people to start trying to look at why i have a blinking square in my car because it is too big to be an alarm LED...
Old May 23, 2013 | 03:00 PM
MrKlean187's Avatar
^yea, I thought about that too! Unfortunately, my car got T-boned the day after I got it out of the shop...
Old May 23, 2013 | 03:59 PM
BLAQ&GREYs2k's Avatar
Maybe for civics, not an S2K
r_duff
Sep 25, 2006 12:06 PM
AlX Boi
Jul 3, 2006 06:24 AM
jarod
Jul 27, 2004 12:04 PM
5thgenbliss
Nov 22, 2001 11:35 AM
5thgenbliss
Nov 22, 2001 01:08 AM
