EMS Help! AEM or HONDATA
Old Oct 9, 2007 | 10:30 AM
Emirhan's Avatar
Default EMS Help! AEM or HONDATA
Hondata has made a new egine management system for 2000-2005 S2000
It uses the K-Pro interface as RSX
But on the other hand there is AEM fully programable EMS
It is hard to decide which one to choose
I would be glad if you would help
Thanks a lot!
www.hondata.com for the new ECU of hondata
Old Oct 9, 2007 | 12:57 PM
JSWhaler's Avatar
Depends on what you want to use it for. A lot of Hondata is plug and play with preset maps while an AEM is fully programable and will not pass emissions.
Old Oct 9, 2007 | 01:28 PM
HARDtoTOP's Avatar
Then there is the emanage ultimate to consider as well.
Old Oct 10, 2007 | 08:20 PM
AusS2000's Avatar
The Hondata looks pretty good but requires a few sensor changes so is not exactly plug and play.
The AEM with an emissions compliant tune will pass any test the Hondata will but if the emissions test include a visual inspection of the ECU then both will fail.
And an E-manage Ultimate is a piggyback so not really in the same ball park.
Old Oct 11, 2007 | 10:43 AM
HARDtoTOP's Avatar
I believe the AEM (I don't know about the Hondata) will fail in some states that plug into the OBDII harness. Massachusetts does this type of testing before they throw the car on the dyno for emissions.
Old Oct 13, 2007 | 08:15 AM
N2oExpresS2k's Avatar
Hondata maintains factory startup and alot of factory features of the pcm. It's not really plug and play but it doesn't require the type of genius the AEM does to tune it. It can be tuned to a much finer degree from what I hear from people who work with it as well.
Old Oct 14, 2007 | 06:59 PM
nMeOnE's Avatar
uhhh i dont think the obdII port will work with the aem ems, it will work with the hondata but you still wont pass b/c its a different vin
bobby.is.rad
Apr 15, 2011 03:05 AM
Bullwings
16
Nov 24, 2010 11:58 AM
vietdragontekx
Nov 21, 2010 07:52 PM
Anthonymv
Dec 27, 2002 08:58 AM
