Extra USB charger on radio circuit?
Old Nov 22, 2020 | 10:06 AM
hill2button's Avatar
Default Extra USB charger on radio circuit?
Would it be ok to tap 12+ and ground of the radio circuit to install an aftermarket USB charger like:
https://www.conrad.be/p/procar-67323...-usb-a-1172667
Or is this a no-go?
Maybe with an additional in-line fuse?
Old Nov 22, 2020 | 02:50 PM
Chuck S's Avatar
You can get ignition switched and non switched 12vDC directly off the fuse block under the dash. No need to cobble something together or tap into anything.
A photo of the connections will no doubt magically appear as soon as someone else reads this.
-- Chuck
Old Nov 22, 2020 | 05:56 PM
oth's Avatar
oth
Your wish is my command!
E - on with the headlights
D - on all the time
C - on with the ignition
Old Nov 22, 2020 | 07:26 PM
Chuck S's Avatar
Told ya!
-- Chuck
Old Nov 23, 2020 | 02:19 PM
Thanks, what kind of connector fits into that ? And I am guessing this still requires a fuse since it is "unfused" by default?
Old Nov 24, 2020 | 05:57 AM
Chuck S's Avatar
Yep, will need a fuse.
Standard 1/4" connector. Picture from the Lowes website. You need the one on the right.
-- Chuck
Old Nov 24, 2020 | 09:57 AM
Thanks!
I tried something new yesterday: my new HU has USB but with a normal USB cable in it, I can't close the door. So I took the slimmest USB cable that I got lying around and dremeled off as much as I could to make the door close. I then threaded the cable over the HU to the back and then back out from the side. So as long as this works, I am not going to need the extra usb charging port.
Old Nov 29, 2020 | 09:02 AM
SOL1D's Avatar
If you’d like the actual connector of it, i mean the spade works fine but if you want options.
https://www.scienceofspeed.com/index...0-2000-09.html
jor-don
UK & Ireland Meets & Events - Past
Apr 26, 2018 07:04 AM
NFR2003
Jan 15, 2018 08:49 AM
jdmkam12
Oct 11, 2017 09:38 PM
AP2SSM
Sep 8, 2017 03:13 AM
