Finally ordered the Spods...
Old Sep 23, 2006 | 08:57 AM
ONEQUIKSTI's Avatar
Default Finally ordered the Spods...
I am using a local guy here (right across the street from my job) for the install work!!! Here is the deal...Alpine CDA9856 Alpine HU, Coexel Polk DB650's, Polk Coexel for the Spod's, and the ipod adapter installed $850 (including shipment of the Spod), not a bad deal???
Old Sep 23, 2006 | 09:30 PM
Dave-ROR's Avatar
Coaxial for the front? or did you mean component? Use components up front.
Old Sep 24, 2006 | 08:22 AM
ONEQUIKSTI's Avatar
Coaxials all the way around (not installing an amp)
Old Sep 24, 2006 | 09:14 PM
Dave-ROR's Avatar
An amp has nothing to do with it.
What do you plan to do with the tweeters in the door already since the stock honda setup is a component setup (well without a real crossover network but the door speakers are NOT coaxials)?
Old Sep 25, 2006 | 02:05 AM
ONEQUIKSTI's Avatar
Not sure yet, I plan on doing all of this when my Spods come in...which will be by next weekend...
Old Sep 25, 2006 | 05:18 AM
Dave-ROR's Avatar
Why not just buy the right speakers for the front? The right speakers in this case being components instead of coaxials.
Old Sep 25, 2006 | 05:54 AM
snakeeater's Avatar
Get the best speakers you can afford. And you can afford separates.
Old Sep 25, 2006 | 03:20 PM
ONEQUIKSTI's Avatar
Shouldn't the components work with an amp? If so I don't intend on using an amp due to the size or the inside cabin (also should be cheaper with the coaxels), keep in mind I picked them up 2 weeks old for $50 in the box from a coworker of mine...
Old Sep 25, 2006 | 03:55 PM
Dave-ROR's Avatar
You can run either with or without an amp. Some components have very low sensitivity, or run at 2 ohms, and should be amped. Many component sets do not need any more power than the 9856 can put out. I (and many others here I'm sure) run components without an amp. The stock door speakers are components and they don't have an external amp either.
In the end, it's your car so do what you want but you may be happier with the result if you put components up front.
If you run the coaxials, you'll want to disconnect the OEM tweeters unless you like bright highs.
Old Sep 25, 2006 | 05:42 PM
ONEQUIKSTI's Avatar
Thanx for your advice...I am off on Thursday, if you are in the Westchase area give me a hollar!!! Would love to check out your setup before I finalize the completion of my system...
