finnaly gonna try active setup
Old Mar 2, 2010 | 06:44 AM
camuman's Avatar
Default finnaly gonna try active setup
after two years of laziness, i am finnaly gonna take neutered sputniks advice and do the active setup.
stuff
mb quart qsd216 6.5" components
pioneer preimer p980
jl 12w6v2 in wlaurent box
jl audio 500/5 amp
gonna send 100 watts a channel to the mid bass and 25 a channel to the tweeters.
soooo, what is a good crossover point to start at for the mid to tweeter? i was thinking of going thru the external crossovers the qsd came with since it allows biamp that way, i would never go below what they think the tweeter was meant to see, but i really have no idea where to start.
advice needed
Old Mar 2, 2010 | 07:43 AM
ungucpho's Avatar
3k hz, it depends on your crossover slope as well
Old Mar 2, 2010 | 05:46 PM
Neutered Sputniks's Avatar
with 3k.
Old Mar 2, 2010 | 06:35 PM
GTS Jeff's Avatar
IMO you can't just take a random number (ie. 3k) and slap it onto any and every setup you see. I think a good starting point would be emulating the specs of external crossovers that come with the components. I know for a fact that MBQs specs are easy enough to find.
Now here's the rub...I don't think the 980 has a 3way active built in. I know the 880 does, but I dunno about the 980.
Old Mar 2, 2010 | 06:39 PM
3K is the starting point. And that's a damned good one.
But, hey, you know more about this stuff than I do.
Old Mar 2, 2010 | 06:48 PM
camuman's Avatar
i honestly just wanted a place to start. external xover is 2500 so i could start there.
and i messed up, i have a 880prs
Old Mar 2, 2010 | 06:50 PM
GTS Jeff's Avatar
[QUOTE=Neutered Sputniks,Mar 2 2010, 09:39 PM] 3K is the starting point.
Old Mar 2, 2010 | 07:01 PM
Originally Posted by GTS Jeff,Mar 2 2010, 10:50 PM
How is an arbitrary number better than starting at the manufacturer's number which they've spent time tuning and R&Ding? Otherwise, why bother with the differences in xovers? Why don't all components ship with a standard 3k crossover box?
I don't think I know more than you. I think that we're both expressing opinions, and it's up to the OP to decide what to do based on how whose opinions make more sense. There's no need to get defensive.
Ahhh, but 3k is not an arbitrary number.
3k is the crossover frequency for most tweeters. Actually, it's closer to 2.5k, but 3k is safer than 2.5k (trying to stuff bass into a tweeter is akin to trying to stuff a basketball into a pigeon - it's not going to turn out well).
So, as you can see, it is not an arbitrary number.
GTS Jeff's Avatar
Ok, since I am heavily procrastinating on the studying, I looked up the exact specs for you.
tweeters: 18 dB/octave, 2.4 kHz high-pass filter
mids: 12 dB/octave, 2.4 kHz low-pass filter
Then I'm not sure what the HPF for the mids are...but human ears are very sensitive in that frequency range, so it won't be hard to figure it out by listening.
Awesome that you have an 880. I love that shiet!! Set it to 3 way mode and give'r! If anything, I would work up from 2.4k, not down. Also give the microphone auto-tune a shot. The auto-tune worked quite well for me and got "close" to what I wanted.
Old Mar 3, 2010 | 06:30 PM
camuman's Avatar
ok even funnier, i actually have the 800prs. im a tard. def has NW setup and should be trying this during weekend.
