Focal 165K vs 165K2...what's the diff?
Old Oct 10, 2002 | 09:49 AM
johnnydev's Avatar
Default Focal 165K vs 165K2...what's the diff?
...and is it worth $80. I can get the 165K's for $250, the K2's are $320.
Thanks,
jd
Old Oct 10, 2002 | 10:04 AM
TepEvan's Avatar
I had the same question. I think the 165K's are the older model. They don't handle as much peak power and have a lower nominal power rating than the 165K2's.
Old Oct 10, 2002 | 12:21 PM
johnnydev's Avatar
Ok, ok, I should have done a little more research. TepEvan, you were right - the K2's handle more power. Also looks like the v.coil (voice coil, right?) is larger and the magnet is bigger on the K2's.
Well now we know
165 K
Old Oct 10, 2002 | 01:25 PM
TepEvan's Avatar
Yes, and I believe the mounting depth is deeper for the 165k2's, but I know there is at least one person on s2ki that has them installed. I think you need 3/4" spacers to get enough clearance between the magnet and the window. Focal sent me a document on the 165k2's (even though I asked about the 165k's). It doesn't make as much sense as it should though Check ebay, a lot of times they have good information about the product... when all else fails, ask a quality installer. But make sure you have all the info first to see if they're bs'ing you. "suuuure we can put there two 15" subs in your door panels and run them off the stock head unit"
Old Oct 15, 2002 | 10:37 PM
Holman's Avatar
for those of you that have heard both, are the 165K2 better over the 165k? if so, is it a marginal improvement? or pretty significant?
DHonovich
Apr 18, 2017 11:37 AM
Jeremy Clarkson
Feb 1, 2013 09:57 AM
gnows2k
Oct 18, 2012 10:08 PM
kenstyle
Jul 17, 2009 08:20 AM
Frisky
Aug 1, 2007 03:26 PM
