a good combo display gauge?
Old Dec 29, 2007 | 02:25 PM
cbrguy7's Avatar
Default a good combo display gauge?
I'm looking for something that will give me the info I need all in one small unit,kinda like a vafc2 where you can switch between different digital gauges and see what goin on(I dont really need it for tuning), ... are there any others out there that do basicly the same thing?
Old Jan 2, 2008 | 05:07 PM
cbrguy7's Avatar
what about the blitz R-VIT Type 1/Type 2? does anyone have one or know anything about em?
Old Jan 2, 2008 | 06:06 PM
Sikocivic's Avatar
Have you seen this? Looks like it could do the job for you.
http://www.brockwayengineering.com/r920.html
Old Jan 3, 2008 | 12:15 AM
cbrguy7's Avatar
thats exactly what I'm looking for do any other companys make something similar that are a little more complex as far as the display goes, (something you would be willing to mount on your dash.)
Old Jan 4, 2008 | 04:09 AM
MikeyCB's Avatar
It's not overly pretty, but you could check out the ScanGauge II.
http://www.scangauge.com/
Countless people have put them in their S's now and find them very functional. Many folks mounting below and in front of the radio door.
Old Jan 7, 2008 | 03:42 PM
cbrguy7's Avatar
what about the Defi-Link Display?
http://www.defi-shop.com/product/dp/dp_top.html
Old Jan 7, 2008 | 03:47 PM
cbrguy7's Avatar
has anyone used or heard anything about that defi unit? It looks like you could pick up the Defi-Link Display with the required Control Unit II for around $350 total..
Old Jan 8, 2008 | 10:10 AM
lYellowDragonl's Avatar
looks like a super good buy for no wire cutting/ tapping
Old Jan 8, 2008 | 01:20 PM
MikeyCB's Avatar
That's the general concensus! But apparently not what the OP is looking for since he seemed to take no notice of it It actually does all sort of data logging as well that can be downloaded to a computer, I believe.
Can also be transferred from vehicle to vehicle because it simply plugs in to the OBDII port and you're up and running. Reads and erases CELs, the list goes on and on...
Old Jan 11, 2008 | 09:46 AM
cbrguy7's Avatar
I think I found the one I'm buyin
Greddy Intelligent Informeter
Designed with a compact plug and play color LCD display, the Informeter allows you to monitor, set warning points and datalog your vehicles performance though it's own On Board Diagnostic sensors. Select through important signals like Speed, Tach, Temps, Air Flow, Voltage, etc. (up to 25 channels depending on application), to monitor. The easy to use navigation menu allows you to select between various screens and displays: Digital, Analog or Bar Graph and 2ch, 3ch, or 6ch screens. You can also set warning points and pre-warning points, which will alert you with audible and visual highlights of important readings. Datalog up to 6 channels of data, and replay them. This is great for tuning. In addition to being functional the Informeter is also infinitely fashionable. Seamless changes in backlighting color, GReddy signature wall papers and colored backgrounds, along with a clear bezel to install colored face plates or even custom face plates, offer a endless options to match any vehicles interior. And to aid in mounting the unit can flip the display 180 degrees to free even more options. The GReddy Informeter is a key tool for all; beginners to pro tuners.
More info
here
