GPS Mount
Old May 22, 2011 | 06:02 AM
Millions's Avatar
Default GPS Mount
So, I was getting tired of the suction cup mount falling off and finally decided to make a permanent solution. The biggest hurdle was that the mount didn't have an integrated plug, so I had to come up with a way for the unit to plug itself in when it snapped it into position. I just cut off the suction cup part of the mount, and made the rest out of 1/8"x2" aluminum bar stock and painted it semigloss black. Total cost... $5 for the aluminum, and $5 for paint.
Mount being painted
Put together, back view
Put together, side view
Installed
Old May 22, 2011 | 06:23 AM
starrman's Avatar
What is the mount attached too? The dash? How is it secured?
Old May 22, 2011 | 07:06 AM
Millions's Avatar
I used the lower screw that mounts the air vent in the a-pillar, but its also just thick enough to get compressed between the plastic trim and metal. It's very sturdy, doesn't rattle, and only has minimal movement if I'm going over a rough road. works perfectly!
Old May 22, 2011 | 12:48 PM
starrman's Avatar
WOW, that was a really good idea! I just quit using my GPS and started using my Android, mounted on a Modifry mount.
Old May 22, 2011 | 10:35 PM
aphex4000's Avatar
BRILLIANT!!
Old May 23, 2011 | 10:18 AM
Millions's Avatar
I realized i didn't add any pics of just the mount installed
Old May 24, 2011 | 07:33 PM
smohan123's Avatar
Brilliant. I will be going the Modifry dash mount route, but maybe DIY fever will hit before then and I'll give your solution a go. nice work! I'd just be concerned about how well it'll hold up on some really spirited twisty driving? How heavy is that GPS unit? I'd probably use my DROID X for GPS, and it weighs ~155 grams, I think.
Old May 25, 2011 | 09:52 PM
S2K-lester's Avatar
Looks pretty clean and a nice location for the gps
josh7owens
Dec 28, 2011 02:02 AM
Nezil
Mar 3, 2007 03:55 AM
