hardtop wiring question
Old Oct 11, 2010 | 04:00 PM
nsx300's Avatar
Default hardtop wiring question
Hi there,
i just recently bought a s2k hardtop for my 2004, I put the wires together and the harness has one for the hardtop, one for the piece that goes behind the plastic and one that is supposed to go to the side catcher, only problem is the side catcher has no wiring coming out of it, so my question is can i just leave that wire or should I jump it? or what should I do?
thanks in advance.
Old Oct 11, 2010 | 05:49 PM
2Kaputnik's Avatar
Did you buy the catchers used? Maybe somebody yanked the wire out not planning to not use the defroster. Might need to order a new catcher. I see you are in Canada, guess you'll want that defroster. Maybe someone can suggest an electrical workaround.
Old Oct 11, 2010 | 07:25 PM
nsx300's Avatar
yea I will need that defroster, I don't think I need to buy a new holder, I just have to find out if the wires should be connected or not, I think that when the top is put on it connects the two wires and then sends the power to the hardtop instead of the regular soft top.
Old Oct 15, 2010 | 05:36 PM
nsx300's Avatar
nobody on here knows what the wiring to the catchers do?
Old Oct 18, 2010 | 01:27 AM
S2000_FUN's Avatar
Hope this helps
http://www.handa-accessories.com/S2000/s2k2top.pdf
Old Oct 18, 2010 | 05:24 PM
nsx300's Avatar
yea, i saw that but it doesnt tell me what the actual wire does. thank you though, does anyone know what the 2 pin connector does that goes to the side catcher?
Old Oct 19, 2010 | 01:26 AM
S2000_FUN's Avatar
If i am right it cancels the softop rear heated window when you have the hardtop on. If you check the driver's side catcher (the one with the cable) you will see on top a switch. When the hardtop is on this switch is pressed so if you press the rear heated window switch in your car the rear heated window of the softop is not working and it works only the hardtop heated rear window.
SSM-9Krev
Jun 18, 2022 06:27 AM
Mr_brightside31
Dec 22, 2010 12:08 AM
kennethr
Feb 7, 2010 12:56 PM
XLeezardx
Oct 7, 2005 11:40 AM
Chris Type R
Oct 9, 2004 11:17 PM
