Hardwire Nuvi
Old Mar 26, 2007 | 01:38 PM
Dave-ROR's Avatar
Or use a small PDU, or just T off a thicker power wire.
But yes, you can't connect an endless number of devices to one port for sure.
Old Mar 26, 2007 | 03:09 PM
tenchi950's Avatar
Can you specify which spot we can add a fuse line to power our nuvi?
Old Mar 26, 2007 | 04:29 PM
Dave-ROR's Avatar
Did you read the radar detector link that was posted? That will show you were to grab the power and put the ground, just put a wire with an inline fuse on that location.
Old Mar 26, 2007 | 05:38 PM
Filthy Beast's Avatar
Mabey some of you guys know this, cant you buy a piece that plugs iinto the Nuvi 360 mic jack that makes it FM ready.
Old Apr 13, 2007 | 11:00 PM
tenchi950's Avatar
Ok, after reading posts I figure that in order to hardwire a nuvi I will need to tap into the accessory socket in our fuse panel that Honda supplied to us. I will be tapping into the (Ignition) section. I will also be taking apart my Nuvi cigarette charger and then resoldering the inside wires to run a hot wire out of the charger. Details here:
http://www.drumart.com/nuvi/
Finally I should run a fuse holder to protect my Nuvi from frying.
Now my question is: what size amp fuse should I be using in the fuse holder for hardwiring the nuvi?
7.5amp? 10?
Old Apr 14, 2007 | 11:41 AM
Reborn56's Avatar
7.5amp? 10?
What ever fuse Garmin installed in thier cigarette charger, use that same fuse size
I will look if i have time on my cigarette adapter
Old Apr 14, 2007 | 12:28 PM
estribo714's Avatar
I think its 5 amp.
Old Jun 1, 2007 | 07:59 PM
JDM AP1's Avatar
I used a 2 amp fuse. plus i bough a female connector so i dont have to cut up my cig.lighter charger.
Old Jun 2, 2007 | 01:38 PM
Sleepy's Avatar
Here's how mine turned out - I'm pretty happy with it (for now )...
Old Oct 5, 2007 | 07:39 AM
shamoo's Avatar
Sorry to bump this thread.....
For those of you above who have use Modifry's dash bracket for the Nuvi (or any other device), where did you tap into to hardwire the unit? I assume there are wires under the cluster, but I want be sure before I start messing around under there. It was difficult enough prying a tiny bit up to insert the bracket.
If there is nothing under there, is it possible to snake the cord into the same opening that the bracket sticks out of, then guide it down to the footwell through the dash? I would assume it would be pretty difficult to get the wire from the GPS unit down to the fuse area.
Any advice would be GREATLY appreciated.
