Has anybody installed an amp NEXT to the spare tire?
Old Jun 2, 2004 | 03:18 PM
Sparta's Avatar
Default Has anybody installed an amp NEXT to the spare tire?
That little space to the left of the spare tire, as you're standing in back of the car looking forward into the trunk... there's a little space... enough to fit an amp physically, although it might not be a good idea because there's almost no ventilation. Is this insane? I'm looking around the trunk for a place to put my new amp. Want it to be as stealth as can be, but also do not want it to overheat and burn the car down.
Old Jun 3, 2004 | 03:50 AM
Bass's Avatar
i used to have an amp located just above the gas tank but since i am useing two amps now i removed my spare and bought Jim's spare tire amp rack
Old Jun 3, 2004 | 05:34 AM
Sparta's Avatar
Where can I find this "Jim's spare tire amp rack"? Thanks...
Old Jun 3, 2004 | 05:44 AM
modifry's Avatar
Honorary Member
No, not insane.
I've had a Kenwood 50W x 4 above the gas tank for several years and 100k miles with no problems at all. It fits tight enough the insulation on the tray is pressed against the top of the amp but evidently there's enough air space for it to survive Atlanta summers.
I recently added a Blaupunkt plastic amp in the same place for the sub but don't have a picture yet. Here's the Kenwood:
Old Jun 3, 2004 | 05:49 AM
ruexp67's Avatar
Jim is PAS2knut and he has/had? a group buy going on in the GB forum on the amp racks.
Old Jun 3, 2004 | 05:57 AM
afetsman's Avatar
I cut out a piece of wood to fit in the spare tire(I've already had one flat and don't want to be without it) and have an amp and disribution block mounted there.
Old Jun 3, 2004 | 07:31 AM
Bass's Avatar
here ya go
http://forums.s2ki.com/forums/showthread.p...48&pagenumber=3
the only downside is that you no longer have a spare but as i stated i'm running two amps and this was really the only way i could go.. (cross overs are mounted on the bottom) and distrubtion block is mounted behind the amp
Old Jun 3, 2004 | 10:15 PM
marks2002's Avatar
Here's a way to mount one that gives up very little trunk space, has plenty of ventillation, and keeps the spare in place.
Old Jun 3, 2004 | 10:19 PM
marks2002's Avatar
^Oh yeah, no drilling...I used existing holes and nutserts. Mine is made from aluminium, but I've seen nice ones in the same place constructed of MDF and covered with carpet. Just make sure to mount low enough to avoid interferring with the trunk spring.
Old Jun 3, 2004 | 10:41 PM
Z06-KILLR's Avatar
yup, installed it in there...no overheating.
