HAT imagines
Old Feb 12, 2014 | 04:25 AM
switchmorgan's Avatar
Default HAT imagines
Will i need to purchase a spacer with HAT imagines?
Old Feb 12, 2014 | 03:10 PM
oth's Avatar
oth
Virtually no aftermarket speakers fit in the OEM plastic speaker baskets, so you will almost
certainly need to replace them with some sort of spacer ring that you purchase or make
yourself out of 5/8" - 3/4" MDF.
You may want to use some foam speaker baffles behind them for weather protection.
Old Feb 13, 2014 | 01:35 AM
Great Info ta
Sent from my iPhone using Tapatalk
Old Feb 17, 2014 | 02:42 PM
thelonerangers's Avatar
Stupid question, I understand the spacer for the speaker to fit. But I'm a lil confused on the foam for weather protection. Where would I be putting that? I am very curious cause I am looking to change the speakers and my budget just went up and I see a lot of people talk about HAT Imagines.
Old Feb 17, 2014 | 05:42 PM
oth's Avatar
oth
The foam baffle can be placed either between the spacer ring and door, or between the speaker and
the ring, depending on the depth of the baffle and speaker. You'll need to cut at least a hole in
it for the speaker wire, but you may want to cut away more from the bottom to make sure water doesn't
get trapped in it. The point is that rain can get into the door along the glass and drip onto the
speaker, so providing some protection from above is a good idea. If you take a look at the OEM
speaker basket you'll see what you are trying to emulate:
Foam baffle:
Old Feb 18, 2014 | 05:04 AM
Where can I order these roam inserts and also what are the thoughts on hat imagines?
Foam baffle:
Old Feb 24, 2014 | 10:18 AM
MP2k's Avatar
I've got the Clarus components and absolutely love them. They clear the doors by a hair with a 3/4" spacer. It's the plastic button on window glass that comes super close to the magnet when the window rolls down. I wouldn't hesitate on any HAT products but I highly recommend the Clarus line. They were the first time I spent over $200 on door speakers and they were totally worth the silly (to me, at the time) price.
Old Feb 24, 2014 | 01:50 PM
Interesting, I was going for the imagines ... What's the difference ?
Old Feb 24, 2014 | 01:51 PM
I was thinking coaxial in my case
Old Feb 28, 2014 | 11:11 AM
MP2k's Avatar
I just read a lot of reviews all over the internet raving about the Clarus line so they were what I went with. The tweeters mounted nicely into the AP2 door pods and the crossovers tucked into the door with a bracket. If you have an early AP1 without the tweeter pods and wanted to stay coaxial the Imagines will definitely be a nice upgrade from stock. If you went with a nicer component set it can be made to work. I mounted a component tweeter in my old AP1 right next to the speaker in the door. I then drilled out some of the faux holes in the door panel speaker cover over the location I mounted the tweeter. Not the most ideal location for a tweeter but I was very happy with it and it was unnoticeable from view in the cabin.
