Head Unit for MY02
Old Jun 21, 2005 | 08:45 PM
RobC2's Avatar
Default Head Unit for MY02
Can anyone recommend a decent head unit that matches the stock dash lighting fairly well? I have seen some Alpine units online that light up in just amber and are not switchable, which would be great, but they don't seem to be sold in the US. The only stores that seem to carry them are British or Russian for some reason. I am not after all the latest features, I am just trying to add slightly better sound while keeping the stock look. Thanks in advance for your help.
Old Jun 22, 2005 | 09:33 AM
TR-S2K's Avatar
Nakamichi CD400 is one that you want to take a look at, it looks almost stock and the iluminations can be selected from either amber or green. I have it in my S and I love its simple faceplate. You can get one for about $300 or less.
FEATURES
- Rotary Encoder type volume control
- Detachable face with carrying case
- Wireless remote control
- CD changer control capability
- 8-cm (3") CD play w/o adapter
- PLL tuner,18FM/12AM PS
- Loudness / Audio mute
- Subwoofer preamp output (RCA)
- Aux input (RCA)
- 6ch/4V Preamplifier output (RCA)
- Auxiliary Inputs (RCA)
SPECIFICATIONS
- Max.power 47 x 4 @ 4 ohms
- D/A Converter Type 24-bit
- Frequency Response 20Hz-20,000Hz (CD)
- Signal-to-Noise Ratio Better than 100dB
- FM Frequency Range in 200kHz steps 87.5-107.9MHz
- AM Frequency Range in 10kHz steps 530-1710kHz
- FM Sensitivity 15dBf(IHF)
- Preamplifier Output Level 4V
- Tone Controls
- Bass 100Hz 11dB
- Mid 1kHz 11dB
- Treble 10kHz 11dB
https://www.cbrstereo.com/index.asp?PageAct...PROD&ProdID=450
Old Jun 22, 2005 | 09:40 AM
tcho82's Avatar
I've got an alpine 9833, and I can swith the lights from Amber to Green, and the buttons I can switch between about 300 colors, To match the dash I can select amber buttons along the bottom and then color match that to the rest of the display.
Old Jun 22, 2005 | 01:35 PM
PJK3's Avatar
i recently acquired an Alpine 9833 with all amber lighting for buttons. it replaced an Alpine 7894 which also had all amber button lighting. both have bluish screens.
the current Alpine 9855 has a black and white lit screen with all amber lighting as well.
there are a number of options out there. the upper Alpines generally have selectible colors that match pretty well.
self serving plug:
if you'd have been a tad bit earlier i could have offered you first shot on my older 7894. i'm currently trying to sell it locally. i don't have money in hand yet, but a local guy has 'dibs' on it. if he doesn't come through, would you be interested?
https://www.s2ki.com/forums/index.php?showtopic=299894
our local group is pretty tight, so regretfully the price will go up a bit for a stranger, but not unreasonably so. say $150 + S&H? there are several people here who can vouch for me.
Old Jun 22, 2005 | 03:11 PM
revhi's Avatar
My 9835 matches perfect amber and red.
Old Jun 23, 2005 | 03:56 PM
RobC2's Avatar
Hello all,
I have decided to stick with the factory head unit for a little bit. Thanks for your help. I am happy to know that there are some Alpines that match well for the future. It is hard to tell because all of the sites show them lit up in green or blue. Also in case anyone is curious, here is the one that I wish I could find in the US:
http://www.caraudiocentre.co.uk/prod...?product=20760
Old Jun 23, 2005 | 04:22 PM
Ks320's Avatar
Does the "SwingFace" (I'm assuming that means the face plate will swing when you insert/eject the CD) interfere with the stereo cover on the S? Such as ... did you have to make modifications to make the swing face work okay?
Also, does the "OEM Steering Remote Ready" of the Alpine unit let you work with you 9855 unit?
Maybe I'm asking too much .. but if you have pics ... can you post them as well?
Thanks!
Old Jun 23, 2005 | 04:26 PM
Ks320's Avatar
I meant:
Also, does the "OEM Steering Remote Ready" of the 9855 Alpine unit work with the volume control on the driver's side's dash?
had a long day at work ... was typing garbage ... thanks
Old Jun 23, 2005 | 05:23 PM
PJK3's Avatar
looks like the CDA-9845 has Quad Illumination and does Amber.
http://iweb.alpine-usa.com/pls/admn/item_i...ain=10&p_more=y
problem solved for about $30 more.
swing face is no problem.
OEM Steering Remote adapter works w/ the S2000, but is still coming to market right now.
TR-S2K
Jun 2, 2004 10:19 AM
LILRED2
May 27, 2003 05:09 AM
Kuwait_S2000
Dec 22, 2001 02:11 PM
DouglaS2000
Aug 31, 2001 06:52 PM
NJHB
Aug 7, 2001 03:14 AM
