Heater fan speeds
Old May 9, 2005 | 03:43 PM
Wingman Gold's Avatar
Default Heater fan speeds
Can you help????
I have a 95 Honda Civic HX 2-door, 5-speed. The problem is in the heater mode, the two slowest fan speeds do not work, two upper speeds work fine. Did not check air-condition mode because the weather is not warm enough outside. Fuses appear OK. Any suggestions would be great. Thanks in advance.
Wingman Gold
Old May 10, 2005 | 06:37 PM
jah's Avatar
jah
here is a on line manual with a schmatic of the honda civic. speed selection done by a resistor devider and a the speed select switch. dont know where the resistor is located but it may be the easy to verify. the fan motor is below the glove box. above where the passenger right foot, maybe the resistor is there too.
the selector switch has a odd logic pattern to it, guess you could start there, may have to remove the radio to access the heater controls.
high probability its the switch, the fuse is good because the hi speed selections are working, just a thought... if 2 speeds are gone maybe only a wire is loose on the switch or resistor.
Old May 12, 2005 | 08:42 PM
modifry's Avatar
Honorary Member
I have no info on your specific car, but if it does use resistors as jah stated, they will be mounted inside the fan housing.
The resistors will get hot as Hades during operation so they put them in the air stream to keep them from frying. Oddly enough it's the slow speed resistors that get the hottest, so it doesn't surprise me that they would go first.
k00leo
Oct 19, 2025 08:39 PM
flyerr
Feb 2, 2015 08:05 AM
jesse_ryan
Aug 11, 2014 06:35 AM
p0staboy
May 13, 2011 03:42 PM
haoheomap
Mar 16, 2009 04:58 PM
