? for heavy bass hitters on latch rattle
Need some advice from you hard thumper on what you did to get the rattle out of the trunk latch. I've sound proofed everything else and is stuck on this one. Of course this only happens on the higher level of the bass volume right before the sweet spot. It seems like the trunk is trying to lift up causing the rattle. TIA
Care to describe it a little more? The latch is mostly plastic but, I think I'm hearing metal. I've got dynamat wrapped around the plastic piece already which does nothing. Can you post pics of how and where you tie wrapped? Thanks
Thanks Will. I zip tied what I think you meant then I took of the plastic cover and I even lowered the latch hook. Now I could say "trunk tight" lol. Seems to take car of that. Now I'm cranking even louder and there is something under the car that is rattling. I'll have to wait to find somewhere else I could crank it up and get under the bottom to find this one. Even way out in the driveway it's knocking stuff off shelves in the back of the house lol. Thanks for the tip.
