Help with my Spods please
Old Nov 11, 2005 | 09:23 AM
SheDrivesIt's Avatar
Look two posts above yours. Are you saying this info is incorrect or not clear?
Old Nov 11, 2005 | 09:30 AM
GranPrix's Avatar
DrCloud is correct, his problem was that he did not have the male connector so he did his own rig to connect the wires. What I simply did was use an OEM 4-pin male socket from my accord and just but the wires together.
Old Nov 11, 2005 | 09:32 AM
GranPrix's Avatar
btw, i love ur sig of the s, where can i get one in white?
Old Nov 11, 2005 | 10:16 AM
jwa4378's Avatar
I went and cut off a 4-pin male connector from the tail light of my 93 Accord
I didnt think you could use that wire.....I thought all real electrical wiring is solid-strand wires, not twisted like speaker wires.
I would make sure the "extra" wire you are salvaging is the correct type of wire.
John
Old Nov 11, 2005 | 10:33 AM
Ruined 2's Avatar
John
Just about anything 12v, especially stereo applications, should use stranded wire. Solid core wire is usually for 110v.
Old Nov 11, 2005 | 12:29 PM
The car in the sig came from another member called i_heart_my_DB8. He created one in each color and gave them out to first come, first served. He asked that no one copy them as they are his intellectual property -- I think he is a graphic designer. You can ask him if you want. Some folks have copied them and I have seen them used around the board but like I said, he asked that people not do that.
Oh, and I agree, all automotive wiring I have ever seen is stranded.
Old Nov 14, 2005 | 08:33 AM
jetboater's Avatar
you can get just the factory headrest speaker harness by itself (H and A installation instructions for the factory instructions show how it's connected)---that way you can get the radio end connection--it has two wires for each side to run the two speakers in each headrest but caould be easily apapted for the Spods--it's only about $11 from Hardtopguy. I ordered one myself yesterday
Old Nov 14, 2005 | 04:14 PM
Argetni's Avatar
You should call Jeff and cancel that order as it is not the part you think it is!!
Been there done that.
Old Nov 14, 2005 | 06:26 PM
jetboater's Avatar
OOPS--I believe you're right on the description -I went back and took another look and it doesn't appear to be OEM. but what I mainly need is the speaker wire connections at the radio. does it come with that? (it appears so.)
here's the site
http://www.hardtopguy.com/store/customer/p...8&cat=30&page=1
thanks for your help!!!!!
Old Nov 15, 2005 | 09:01 AM
GranPrix's Avatar
here's the site
Jeff doesn't even have a pic of the harness.
Anyway, what are you connecting, the speakers from the Spods to the stock HU?
