HELP! RSX Sub drained my battery!
Old Sep 9, 2004 | 09:26 AM
Diatomic's Avatar
Thumbs up HELP! RSX Sub drained my battery!
I installed the RSX sub into my S about a month ago. And this morning, after being gone for the long weekend, I find my S out of power.
I think the subwoofer drained my battery. I tapped the 12v "MEMORY" power from the head unit which I think is always on
Is there any device I can get which will automatically shut off power to the sub if it goes inactive for a period of time. Or do I need to reroute power? Is there something else from the head unit I can tap that's not always on?
I read the usual threads but didn't get a clear answer on power. Half the peeps seem to already have an amp hooked up and just tap that. Search isn't helping either since it doesn't like short 3 letter words like "RSX".
Any help would be appreciated!
Old Sep 9, 2004 | 09:29 AM
hatchimon's Avatar
tap it to the ignition wire not memory
Old Sep 9, 2004 | 12:47 PM
steven975's Avatar
yep, use the 12V ignition wire. It is on when the key is in ONLY.
amps run from the 12V always on line, but they use a separate signal wire that turns the amp on when the radio is on, much like a relay. The RSX sub lacks this. There is more than enough amperage for a deck and RSX sub on the 12V ignition line the radio operates on.
Old Sep 9, 2004 | 01:24 PM
Diatomic's Avatar
That makes sense. I think I just jumped on the memory wire because it was the first wire with a 12v marking on it.
Thanks guys.
Old Sep 9, 2004 | 09:36 PM
Diatomic's Avatar
Switch wire. Working well.
Thanks.
Old Sep 10, 2004 | 12:21 PM
PokS2k's Avatar
If for some reason you still have problems then set up a switch relay.
Old Sep 10, 2004 | 03:23 PM
Diatomic's Avatar
Is there a thread you can point me to on how to do that?
Old Sep 11, 2004 | 05:03 AM
PokS2k's Avatar
You would need to buy a 30A Switch Automotive Switch Relay (about $5 from Radio Shack).
You then wire it like this:
I have an Alpine deck and it is hard wired to the battery. That being the case the normal yellow 12V from the harness is free. This is the one that I have going to #30. It supplies the postitive power. If your HU is connected to the harness power then you would tap into that one. Put an inline fuse in the line.
#30 - Constant 12V (+) Always live
#86 - Ground
#85 - Remote Amp Turn on from Receiver (Switches the relay on and off, allowing the juice from #30 to go to #87) Your HU needs to have an Amp Turn on lead.
#87 - Juice to Bose Amp.
hondavet
Apr 9, 2013 04:55 PM
13darkknight
Apr 16, 2009 10:38 PM
FinancialPlanner
Aug 3, 2008 12:06 PM
toosteeley
Jun 7, 2004 08:09 AM
jays2000
Nov 20, 2003 06:15 PM
