help w/gauge install
Old Feb 22, 2005 | 11:07 AM
don cornelius's Avatar
Default help w/gauge install
can someone give me a very detailed description on how to wire 2 electronic gauges.. one is water temp and the other is oil pressure.. attempting to do on my own...please help....
Old Feb 22, 2005 | 05:13 PM
AusS2000's Avatar
The electronics for this is fairly simple. It's the plumbing that is trickier. Check Under The Hood forum. I know there was a pretty good write up about an Engine Coolant Temp gauge a while back.
Old Feb 22, 2005 | 05:19 PM
darkknight1999's Avatar
I can help you. What gauges do you have? Also please list all the parts you have on hand right now. I just want to make sure you have them all, or I can tell you what your missing.
I have oil pressure and temp. myself and they work awesome.
Old Feb 22, 2005 | 07:34 PM
xviper's Avatar
If you don't mind doing a little reading, here are two threads I did on installing two different brands of guages:
https://www.s2ki.com/forums/index.php?showt...l=gauge++sender
https://www.s2ki.com/forums/index.php?showtopic=99530
Old Feb 23, 2005 | 04:37 AM
iCEE's Avatar
i'm thinking about installing oil pressure and oil temp gauges. either greddy or defi.
which did you use? where did you mount the sending units?
Old Feb 23, 2005 | 08:22 AM
Alright what i have well what i order (have not received yet but wanna be prepared) is autometer carbon fiber 2 1/16" electric gauges that say they come with probe, wiring harness, and instructions....ill be mounting them into a autometer dualgauge pod, so is there any other items ill need, can i get a step by step with items needed from some one please???
GpWaP1 s2k
Jun 10, 2009 07:48 PM
2QYK4U
Mar 25, 2007 03:51 PM
S2K000
Sep 23, 2006 05:27 PM
s2krey
Jun 18, 2006 10:29 PM
s2k_9000rpm
May 22, 2005 04:37 PM
