Here are some sub selections... which would you choose?
Old Jun 27, 2004 | 07:33 PM
CeleSaga83's Avatar
No. 1 SW8102DVC - Eclipse 10" Aluminum Subwoofer
Santoprene Surround
Aluminum Cone
Dual Mirror-Image Spiders
Aluminum Voice Coil Former
"Bottomless" Design
Aero-Vented Pole Piece
Cast Aluminum Frame
Double-Stacked Magnet
Small Sealed-Box Enclosure
Continuous Power Handling: 500W
Music Power Handling: 1,000W
New Dual Voice Coil (SW8122DVC)
QCA (Quick Change Assembly)
Fs: 27Hz
Qts: 0.30
DCR: 4.0/coil
Vas: 3.20cuft
Xmaxone way) 1.30"
No. 2 Image Dynamics 10" ID MAX D4 V.3
Rec. Sealed Box Dims: 1.00 - 1.50 cu.ft.
Rec. Ported Box Dims: 1.50 - 2.00 cu.ft.
Free Air Usage: yes
Sensitivity: n/a
Frequency Response: 20-250 Hz
Recommended RMS Power: 1000W
Peak Power Handling: 1800W
Impedance: dual 4 ohms
No. 3 10W6 JL Audio 10" DVC Subwoofer
Nominal Diameter: 10 inches (250 mm)
Continuous Power Handling: 300 Watts
Voice Coil: 2.5" diameter, 4-layer, Kapton former
Available Configurations: Dual 6 ohm
Xmax (one-way, linear): 0.47" (11.9 mm)
Sealed Enclosure Range: 0.40-0.80 cu.ft. (11.5-22.5 liters)
Ported Enclosure Range: 0.90-1.25 cu.ft. (25.5-35.5 liters)
VRC
Old Jun 27, 2004 | 07:59 PM
NFRs2000NYC's Avatar
Well, of the ones you picked.....(you didnt consider price)
I would only go for the DVQ or the Eclipse. The DVQ has adjustable motor structures which can optimize it for any enclosure (a very big difference can be had)
I would also stick my sub on that list, as it is one of the best Ive ever tried, Alphasonik 800 series 10"
$200 buys a LOT of subwoofer today, so choose wisely. The DVQ is more SQ oriented (hence the lower power rating).....but is incredibly tight and accurate is set up correctly. I PMed you a response, so we can work from there.
Old Jun 28, 2004 | 12:45 AM
timg's Avatar
All four of those are excellent choices. I think you would be very pleased with any of them, I know I would!
The first questions in my mind are depth and airspace. How much mounting depth are you going to have and how big can your box be?
Once you know which will physically fit, then I'd figure out how much amp you want(1000 watts, or 300 watts).
After you figure out those 3 parameters, I think you'll have narrowed your choices down to one.
Tim
Old Jun 28, 2004 | 12:01 PM
devilchrist's Avatar
I have the infinity 10 DVQ.. I love it.. but it requires a box that's a bit oversized.. my box sticks about 3/4" obove the deck.. and that's gives only 1" clearence from the bottom of the box to the rear of the speaker...
JL W6v2 has requires slightly less depth..
NFR what's the depth requirement for your alphasonic?
Old Jun 28, 2004 | 04:20 PM
not sure...check the website....www.alphasonik.com
TRD_Celica
Nov 29, 2009 03:03 PM
BirdsS2K
15
Jul 8, 2009 06:37 PM
1st07inOH
Dec 6, 2007 06:26 AM
ScottyBallistic
Aug 17, 2005 03:25 PM
