Here is what I might get... Opinions wanted.
Old Feb 26, 2004 | 08:08 AM
Celeritas's Avatar
I have been doing some shopping and want to get your opinions on the setup I plan to have installed. Part of the reasoning for my choices are that I really like the shop that sells this stuff, so I will note where I am buying something they sell instead of a different product. Also, I listen mostly to Pop with some Hip Hop and Country. Bass needs to be full, but not extreme.
Head: Clarion DXZ745MP - The shop sells Kensood, Sony, Pioneer, and Clarion. No alpine, as there is a dealer down the street. This unit plays MP3s and has 4 volt preouts, so I figure it will be fine. Also, the face is flat while on so I don't have to worry about fitment with the door and Modifry makes a DCI for Clarion.
Speakers: MB Quart PCE 216 - I know that these aren't everyone's favs, but I listened to them with this equipment and like them. Also, I have MB Quarts in my Integra and have been happy with those. There is no Focal dealer near me, or I would check them out.
Sub: JL Stealthbox - I have read good and bad things about this unit. The shop has installed several of these with good results. I need to use the tool well as I carry long obejcts often, so the Wlaurent box is not a good option for me.
Amp: JL Audio 300/4 - The fronts will get 75w each and the sub will get the rear channels bridged.
This will be mounted above the fuel filler tube in the trunk.
On a side note, (if you have read this far) how much will 4 sheets of Dynamat weigh? The shop will do the doors for free, and if there will be no adverse results, I think I will let them do it, even though there are better products out there.
All this installed should cost around 2 grand, maybe a little more. I could save more if I installed myself, but I did that last time and don't feel like doing it again. I will add on the DCI myself after the system is installed. Anyway, I didn't want to make a major purchase for the S without getting some opinions first. Thanks for reading!
Old Feb 26, 2004 | 08:51 AM
Willie Gee's Avatar
Sounds like a good system. Can you really fit qa JL audio 300/4 above the fuel filler? Will it get enough ventalation?
Food for thought:
Consider putting the amp in your spare tire well. Look into getting rid of your spare, it ads all kinds of space to your trunk and increases your options. With a sub in the tool well you have nowhere to put your flat.
Old Feb 26, 2004 | 11:49 AM
darkknight1999's Avatar
The thing about putting the amp above the tank is the wiring going into the tank itself, you don't want to damage it at all.
Bill makes a good point, if you have no place to put a flat tire then you might as well ditch the spare tire and use that space.
Old Feb 26, 2004 | 01:04 PM
marks2002's Avatar
You might also consider mounting the amp vertically, next to the spare...if it's not too big. Have you checked the amp mounting thread?
Old Feb 26, 2004 | 01:45 PM
mikes2k's Avatar
This will free up tons of room!
Old Feb 26, 2004 | 02:22 PM
Celeritas's Avatar
Interesting about not having room for the flat tire. I had not thought of that. I would likely just call AAA anyhow. Why would I bother with changing the tire when they will tow the car for free (flatbed, I know)? If the stealthbox can be made easily removable, I could put it in the passenger seat in the case of an emergency, making room for the flat. I have had car trouble where there is no cell service recently, so I am leary of not having the option of changing the tire and being on my way. As for the amp, the shop I am using has installed JL 300/4 over the filler pipe in 3 S2K's with no issues reported by the owners, so I am not too worried about doing that. I really like a stealth look, which is why I like the idea of the amp being hidden and the sub being unobtrusive.
Old Feb 27, 2004 | 08:22 AM
2004S2000's Avatar
IN a jam could the flat be placed in the trunk, the trunk lid held down with a rope? Is this a problem with both front and rear flats?
UnkieTrunkie
Dec 31, 2014 05:53 AM
Chris92af
Jan 2, 2007 03:49 PM
S2KenC
Apr 13, 2006 12:34 PM
Brutewes
Feb 16, 2004 08:20 AM
JohnsS2K
Jul 2, 2002 10:50 PM
