Hid out
Old Feb 18, 2014 | 01:53 PM
plizzat's Avatar
Originally Posted by modifry
Originally Posted by GranPrix' timestamp='1391397859' post='22995822
If it was a fuse or relay both lights would be out. Like silly said, swap the bulbs first.
Actually, a blown fuse or bad relay would NOT take out both lights, as the low beams are separately fused. Same for the relays - one for each side.
Assuming he has a pre-DRL car, it's unlikely that one fuse or relay is bad, otherwise the bad side would be flickering.*
If he does have a DRL car, I would look first at the fuses and relays just because they are easy to check.
* Because of the way the S2000 is wired, if one fuse or relay is bad and you turn on the low beams, the HID on the bad side will flicker and both HIGH beams will come on real dim. The headlight wiring allows power to back-feed through the high beam filaments to the HID with the blown fuse or bad relay, but since the voltage is reduced by going through both high beams the HID flickers. You can test this yourself if you have a pre-DRL car. Wiring on the DRL cars is different so I don't think it will back-feed, but I never tried it when I had my '08. However, the DRL cars still have separate fuses and relays for each HID.
I Have a ap1. Where would those fuses be located? I checked the two in the fuse box but I think those are for the high beams.
Old Feb 19, 2014 | 06:17 AM
modifry's Avatar
Honorary Member
You might want to consider taking the car to a mechanic, because it's been a couple weeks and you apparently have yet to find the under-hood fuse box.
Old Feb 19, 2014 | 11:07 PM
plizzat's Avatar
I checked the under the hood fuse box. The 2 headlight fuses arent blown, I was just wondering if there was a fuse for the HID.
Old Nov 20, 2014 | 07:35 PM
DCs2ooo's Avatar
In reading some of the replies to this thread, I'm wondering if this is the flickering problem people are talking about with the ballast going bad?
A few weeks ago, the bulb would stay on for a few minutes, then go out (no flicker). Now it's basically not coming on at all. Luckily, it's a weekend car and pretty much put away for the winter.
Thoughts?
http://youtu.be/-BWrkV-ghqw
czirrfb3
Mar 28, 2019 06:58 AM
phyth
Nov 8, 2015 04:20 PM
racer_X_123
Jun 19, 2011 04:07 PM
Gutter
Mar 25, 2007 06:01 PM
s4play
Feb 23, 2007 01:47 PM
