home link installed
well go bored today on my day off so i installed a homelink garage door opener in the s2000
i had an extra visor from my old lexus IS300 so i took out the homelink from that and installed it into the center console arm rest. very happy with the way it turned out i was worried my arm would hit it while driving but its out of the way!
dont know if this has been done before but thought i would share. didnt have my camera with me at the time but if anyone want pics on how to do it i can rip it out agai to take some pics
-Brett
-Brett
Dude.. That awesome.. show some DIY..
I'm getting annoying to open up the compartment then take out the remote.
Please show where how to get that??
Lexus?? how much?? or should I go get from ACURA isntead. hahah
and i dont know about the size of the other homelinks so i would say this might only work with the leuxs IS300 style homelink. as its a tight fit under that arm rest.
-Brett
ok so i found time today to take a couple quick pics of the bottom side so you can see how i mounted it.
had to cut out the plastic so that the homelink would sit flush with the plastic under the material. not really that hard with the lexus home link i just traced it onto the plastic and cut it out with a dremel. then the lexus home link has a little ledge that sat right on top of the plastic arm rest peice once you cut out the hole. then i hot glued it in to make sure it didnt move.
then i cut the padding out that layed on top of the home link so it wouldnt pucker the material. then i adhesive sprayed the material back on like it was stock.
then to cut out your holes with a razor blade.
the i painted the buttons and surround with that "ricer" vinyl dash paint
then click it in. then do you wiring ground and a power
tims2k
Feb 18, 2004 05:29 PM
