Honda Alarm System
When I bought my 06 S I had the dealer installed alarm put in. It is a honda alarm. I did a quick search and couldn't find it. Any idea where it is installed?
If it is a Honda "factory" alarm system, then this should tell you what you want to know.
Honda Factory Alarm
I've found that not all dealers install the "factory" alarm system. Sometimes they use an aftermarket unit the mimicks the factory system but is cheaper for them so the maximize their profit margin.
FWIW!
Hope this helps!
Steve R.
Honda Factory Alarm
FWIW!
Hope this helps!
Steve R.
Originally Posted by AlX Boi,Oct 1 2006, 02:21 AM
hmmm...I got my alarm with the purchase of the alarm system isn't from Honda Factory. I thought Honda just used some other alarm as their factory alarm. Did I get gyped?
Honda's web site, in the "build your car" section, lists the factory alarm at $448. H & A Accessories, the place I linked above, lists it at $273.60 and an added $54 if you opt for the hood switch. That brings it up to $327.60. That's a $120.40 savings. Then you've got to get either one of them installed. If you're up to doing it yourself, you can save that money. I installed a factory alarm system, bought from H & A, in an '01 Odyssey I used to own. It was actually pretty simple as it plugs into existing wiring. The hardest part of the process was crawling up under the dashboard to get to wiring connectors needed but that wasn't really as bad as I expected it to be. On a car as small as an S2000, I'm not so sure that my 6'2" frame could make the squeeze.
FWIW!
Good luck,
Steve R.
FWIW!
Good luck,
Steve R.
