Hooking up a couple of subs to stock stereo...
Old Nov 17, 2003 | 02:40 PM
Kenny_Stang's Avatar
Default Hooking up a couple of subs to stock stereo...
Hey guys, I'm kind of a newb to stereos/electronics and usually focus my money/efforts on performance parts, but I had a question. I have two Kicker 10" Subs and a Sony Xplod 750W amp that I had left over from my past car that I would like to install on my S2K. I'm not looking to update the HU, because in all honesty I can't afford to do so right now.
Well here's my predicament, Saturday after cleaning my car I decided to look around to see if I could install the subs, and found the rear speaker harness behind the seats, now how would I hook up the subs using this harness ( if it's possible ), and is there any wiring diagram showing which wires are what? Can I splice into the wires for the rear speaker harness and use this for the signal? If this is not the best idea then anyone have any recommendations? TIA.
Old Nov 17, 2003 | 04:02 PM
Andy Kirk's Avatar
There should be no prolblem if the wiring to the rear speakers is real, there is no rear speaker wiring in a stock S2000. You may have to change the low pass in the stock HU (if any). I didn't put a sub into my system as it isn;t as necessary for the type of music I listen to.
Andy
Old Nov 18, 2003 | 06:22 AM
[QUOTE]Originally posted by Andy Kirk
Old Nov 18, 2003 | 06:35 AM
PJK3's Avatar
yes, you can add subs and an amp to the stock head unit. you'll need an adapter that will allow you to hook up rears, then go into the amp through some line level converters. Lucid sells a harness that allows you to use the factory stereo rear output.
you might want to try a search looking for: amp stock stereo.
Old Nov 18, 2003 | 06:51 AM
J Nick's Avatar
there is no speaker harness for the 22000 stock - that harness, underneathe the roolbar panel is for the hardtop rear defroster or something
MikeyCB
Apr 8, 2008 09:22 AM
golfpro
Jul 7, 2006 05:00 AM
ruexp67
Apr 22, 2003 08:07 PM
purdue2k2
Aug 30, 2002 09:25 PM
joecro
Sep 9, 2001 10:49 AM
