How can i change the front signal bulb !!
Old Mar 2, 2004 | 07:59 PM
S2000AD's Avatar
Default How can i change the front signal bulb !!
anyone
Old Mar 2, 2004 | 08:11 PM
ImportSport's Avatar
Do you mean your turn signal bulb? This would be the large round one in the upper corner.
You can either pull your front bumper and remove the light assembly.
Or you can pull the screws holding the liner to your wheel well in place. You will need to pull about 4 along the lip and one inside the well right behind the where the light is. These simply loosen the plastic lining. There is one hidden screw right behind the lip of the bumper where it meets the fender. This upside down screw is the only metal screw you need to remove.
Now you can pull back this lining and gain some access to the area behind the light. It will be very cramped and if you have large hands you may want to find someone with smaller hands to reach in and change the lights. Just twist the light out of the socket and pull it out of the tight area. Release the wiring harness so you can easily replace the bulb without touching it.
racer_X_123
Jun 19, 2011 04:07 PM
Stradale
May 10, 2011 11:14 AM
jah
Sep 26, 2007 12:38 PM
Gutter
Mar 25, 2007 06:01 PM
seung
Apr 16, 2003 12:02 PM
