How do you remove the inside of the radio door?
Old Mar 24, 2007 | 06:07 AM
preilly44's Avatar
Default How do you remove the inside of the radio door?
I have the JVC NX-KD5000 GPS radio and I can't quite get it to fit to the point where I can close the radio cover door. Does anybody know how to remove the credit card holder? I believe if I can remove that I'll be able to close the door.
I was advised to use a flat head screw driver but I didn't have any luck with that....if that is the only way to do it, is there a certain place I should try prying it from?
Thanks in advance!
Patrick
Old Mar 26, 2007 | 02:11 PM
preilly44's Avatar
Nobody?
Old Mar 26, 2007 | 02:48 PM
DFWs2k's Avatar
I don't think you can just pry it off, I think you would have to cut it out.
Old Mar 26, 2007 | 02:49 PM
NFRs2000NYC's Avatar
Its all one piece of plastic.
Old Mar 27, 2007 | 10:52 AM
squirrels2k's Avatar
either have to trim the plastic to fit it or get a different head unit
Old Mar 27, 2007 | 11:46 AM
DFWs2k's Avatar
Break out the saw preilly! haha..
Old Mar 27, 2007 | 07:26 PM
SB2007's Avatar
Old Mar 27, 2007 | 07:49 PM
darkknight1999's Avatar
You need your friend the Dremel and a cut off wheel and once your done with that part you'll need a sanding drum to smooth it all out.
Old Mar 28, 2007 | 12:05 PM
DFWs2k's Avatar
Saws are more fun...but a dremel would probably get the job done too...
Old Mar 28, 2007 | 12:16 PM
skill saw and a steady hand
