How to Factory Head Unit Specs?
Old Oct 15, 2002 | 07:26 AM
gohiking's Avatar
Default How to Factory Head Unit Specs?
I'm adding a complete sub/amp/speaker system to my winter car (96 Acura Integra) and am debating whether or not to replace the factory head unit as well. The amp I'm putting in has high-level inputs, so that's not a problem. I'd like to check out the specs to make sure that the signal coming from the headunit will be sufficiently clean.
Any clues on how to find out specs for a factory head-unit?
Old Oct 15, 2002 | 02:36 PM
MacGyver's Avatar
If you're so worried about the specs coming from a factory head as to need them before proceeding to use the head, you're probably not going to be happy with the setup. Remember, this IS a basic head unit and you are going to be using a line-level converter (in the amp itself). If this was the S2000, I'd say the setup was good enough, but with the Integra not being a noisy convertible, you may just hear the difference.
Sorry that I can't answer your actual question, but my question back to you would be "Is this info really worth knowing, considering the setup?"
Old Oct 16, 2002 | 03:59 AM
gohiking's Avatar
Good point, MacGyver. Time for a new headunit....
aggiedave98
Feb 24, 2008 10:10 AM
WestSideBilly
May 28, 2003 06:38 AM
F1 Tech
Sep 6, 2001 07:45 PM
rocketman
Sep 5, 2001 08:57 AM
s2kmtl
Nov 9, 2000 06:49 PM
