How to make speaker brackets
Old Feb 18, 2005 | 01:27 PM
mt rsx's Avatar
Originally Posted by SheDrivesIt' date='Feb 18 2005, 02:48 PM
Do you not understand the words countersunk or counterbore?
Precisely...I never took woodshop class
Old Feb 18, 2005 | 02:01 PM
SheDrivesIt's Avatar
Picture a hole drilled through a piece of wood. The hole, when viewed from the side, will just look like a simple column. When you counter bore or counter sink it, a larger cutting tool (drill bit) is used to open up the one end of the hole so that the head of the screw will fit inside but still tighten up against the wood but the head of the screw will be past the surface of the wood.
If you look at a flat head screw from the side, the head is shaped like a triangle. If you use a drill bit the same or slightly larger diameter than the screw head, you can drill a little into the 3/4" MDF (or wood) just enough so that the head of the screw is not sticking up.
Better?
Old Feb 25, 2005 | 06:43 AM
s2uk's Avatar
thought i would post a picture of mine mounted with the speaker in place.
Old Feb 28, 2005 | 04:30 PM
kmvguy83's Avatar
nice speakers
how do they sound?
Old Mar 1, 2005 | 07:26 AM
s2uk's Avatar
Originally Posted by suzukas2000,Mar 1 2005, 02:30 AM
nice speakers
how do they sound?
have not got them in my car as yet due to it being hit, they have very good reviews though, should get my car back in four weeks so will post once they get powered up.
still a long way to go in building the system only started three weeks ago and most of the bits have only just arrived from the US, so much better price than here in the UK. cant wait to get it all put in the car once its back.
Old Nov 24, 2005 | 09:48 PM
s2kneo's Avatar
Does this create any issues with the door panel?
Old Nov 25, 2005 | 04:03 AM
PAS2KNut's Avatar
No
Old Nov 26, 2005 | 09:42 AM
Dylan Hunt's Avatar
nice nice, I started the process
Old Nov 26, 2005 | 09:49 AM
Dylan Hunt's Avatar
Just wondering, are our speakers 6.5 inch? Because I got 6.5 inch /160mm JL Audio Coaxials and I don't think they fit
Old Nov 26, 2005 | 11:16 AM
AlanL's Avatar
The OEM speakers are slightly smaller than 6.5". I have seen some posts refer to them as "european 6.5". That's the whole reason for this thread - very few aftermarket 6.5" speakers will fit the OEM mounts without building something like this bracket.
My Diamond D661s speakers were considerably larger than the OEM holes, but worked fine with a bracket just like the one described here
