How many feet of wire and how many connectors do I need?
Old Apr 15, 2004 | 09:05 AM
all-trick'd-out's Avatar
Default How many feet of wire and how many connectors do I need?
I will be running one subwoofer wired into 2ohm
I will be running two front 6.1 perfects and plan on re wiring the doors.
I will be using 4 gauge wire for power and ground
I will need a set of 4channel RCA's (which company makes the best stuff) running from the deck to the amps in the trunk. I need to know amount of feet that I'll need. Thanks...
What type of clips/connectors terminals do I need. I am making my own box so I need enclosure terminals etc etc etc.... HELP!
Old Apr 15, 2004 | 09:14 AM
darkknight1999's Avatar
1. Where do plan to mount your cross-overs
2. Where do you plan on mounting your amp/s (trunk, under the seat)
3. Do you know how to solder?
Old Apr 15, 2004 | 11:21 PM
I do know how to solder.
I plan on mounting the amps in the trunk, most likely where the spare tire is.
The crossovers..... I guess in the door panels, unless there is a more practical place to put them.
Old Apr 16, 2004 | 05:34 PM
bump anyone!!!
netanderthal
Oct 9, 2007 06:15 PM
smurf2k
Jul 17, 2006 08:48 PM
Darien1629
Nov 8, 2005 03:05 AM
jaws4096
Sep 29, 2004 09:40 PM
hornsfan
Apr 27, 2004 09:29 AM
