how are you wiring door components in 00-01?
Old Mar 25, 2006 | 01:35 PM
payyourtoll's Avatar
Default how are you wiring door components in 00-01?
I searched but didn't see any info. How are you 00-01 folks mounting your components in the front? Buying 02+ door panels, or what?
thanks
Old Mar 25, 2006 | 02:26 PM
scho01's Avatar
I just installed my Infinity 6.1 perfects this past weekend. Here's where I installed the Tweeters. Used my Dremmel to cut the holes. The crossovers and woofers I installed as explained in the FAQ's link.
Drivers Side
Passenger Side
Old Mar 25, 2006 | 04:07 PM
darkknight1999's Avatar
I can mold them into your a-pillers like this for you.
Depending on your speaker I can either surface mount them:
Or I can inset them into the pillers like this:
Old Mar 25, 2006 | 04:46 PM
rad23racer's Avatar
I made brackets and mounted them to the door cups to see how things sounded. The door cups are $4.21 dealer cost so if you need to replace them, no biggie.
I like the way they sound but am not terribly impressed with how they look.
I mounted the crossover where the foam thing is on the back of the door panel and then cut out the foam to make a tight fit. I would take a picture to show you but don't want to take the door panel off again. Just a minor pain.
Just out of curiousity, how much are the molded tweeters going for? Do you need my a-pillar covers or can I send you mine when I get the molded set? I can send the flush-mount cups from my Polk db6500s if that would make things easier.
Old Mar 25, 2006 | 05:06 PM
those look sweet John!
Old Mar 26, 2006 | 06:27 AM
rad23racer's Avatar
Old Mar 26, 2006 | 06:52 AM
Do you realize you copied the what you wrote...?
If your interested in having these done to your car please PM with info on whatever speakers you have and I'll respond asap.
Thanks
-john
AslanS2K
Sep 19, 2007 02:53 PM
AslanS2K
Sep 17, 2007 08:36 AM
x2ooo
Socal Swap Meet
Jun 22, 2006 08:51 AM
Ajjra
Feb 12, 2004 12:51 PM
