I had a problem after amp install
Old Apr 24, 2004 | 12:14 AM
maverick521's Avatar
Default I had a problem after amp install
My passenger side window won't go down. I checked the fuse and it was ok. I ran my power wire through the passenger side. and I ran the rca, speakers and remote wire on the driver's side. any idea guys?
Old Apr 24, 2004 | 02:27 AM
LATEOTT's Avatar
Did you check the passenger window lock switch on the driver's side controls? It's easy to accidently switch it off during that kind of work. Otherwise if you were working inside the passenger door you might have knocked the plug loose (in which case the door lock shouldn't work either.)
Old Apr 24, 2004 | 07:22 AM
i know for sure it wasn't the switch because the automatic window doesn't work (the one where when you put your soft top up or down the windows automatically go down). I'll have to check plug. I didn't notice if the door lock was working. thanx.
Old Apr 24, 2004 | 07:23 AM
darkknight1999's Avatar
Did you unlock it on the drivers door window switch
Old Apr 24, 2004 | 07:24 AM
Did you take apart your doors at all?
Old Apr 24, 2004 | 07:41 AM
i didn't touch my doors at all.
Old Apr 24, 2004 | 07:50 AM
Did you work under the dash? on the drivers side, moving around the wiring harnesses?
Old Apr 24, 2004 | 09:39 AM
yah i worked under the dash. i pushed the power through the firewall..
Old Apr 24, 2004 | 10:18 AM
i wiggled some wires and the door lock works. i found out that the switch works on the driver's side, but only going down, not up.
Old Apr 24, 2004 | 12:43 PM
umm... that doesn't sound good... What wires did you mess with?
