I had a problem after amp install
My passenger side window won't go down. I checked the fuse and it was ok. I ran my power wire through the passenger side. and I ran the rca, speakers and remote wire on the driver's side. any idea guys?
Did you check the passenger window lock switch on the driver's side controls? It's easy to accidently switch it off during that kind of work. Otherwise if you were working inside the passenger door you might have knocked the plug loose (in which case the door lock shouldn't work either.)
i know for sure it wasn't the switch because the automatic window doesn't work (the one where when you put your soft top up or down the windows automatically go down). I'll have to check plug. I didn't notice if the door lock was working. thanx.
umm... that doesn't sound good... What wires did you mess with?
