I have a CRAZY problem, Junkies-HELP
Old Jan 1, 2006 | 07:25 PM
B.C.'s Avatar
Default I have a CRAZY problem, Junkies-HELP
I got a USED "S" and the only thing wrong was the CD player (OEM). The owner noted that the CD didn't work after the system was de-intalled and OEM placed back in. So I figured the OEM unit is fried. I stuck in an aftermarket unit w/ different amps. AND THE SAME THING happened, no Audio from the CD?!
Here is the low down. FM and AM works TERRIFIC. Put a CD in and no sounds comes out, of the OEM unit an aftermarket unit.
Using 2 amps, and 2 RCA. What's gives??
If I'm using RCA/AMP and the radio works... why wouldn't the CD give me sounds??
BC
Old Jan 1, 2006 | 08:12 PM
darkknight1999's Avatar
Wow that's a weird one... I'm gonna have to think about that one.
I would say to try the stock HU in another S just to see if its toast but since you tried and aftermarket head in the car it must have something to do with the car.
Old Jan 1, 2006 | 08:16 PM
B.C.'s Avatar
I'm running out of ideas... RCA outputs all the music (radio and CD) to amp then speakers.......
This is killing me.
BC
Old Jan 1, 2006 | 08:44 PM
Yeah that's right.
HU to RCA's to Amp to speaker wire from the amp to the stock speaker wire or new wiring. But it doesn't sound like a wiring issue so much because you said that the radio works fine.
Old Jan 1, 2006 | 08:46 PM
B.C.'s Avatar
Originally Posted by darkknight1999,Jan 1 2006, 09:44 PM
Yeah that's right.
I think I got it, with some help.
Power Ant. Lead must be on Accessory Power. I think I went wrong there. The AMP shuts off on CD mode.
I'll fill you guys in a few days..
BC
Old Jan 2, 2006 | 01:03 PM
S2KinVA's Avatar
BC
Yes there should be 2 blue leads, one is antenna and one is amp.... do not use the antenna one as it will shut off when the radio is off.
Old Jan 2, 2006 | 01:54 PM
^ Ditto and that might solve the problem Its always the stupid little things that drive ya nuts
Old Jan 4, 2006 | 12:20 AM
SebringDemon's Avatar
BC
if youre connecting your aftermarket radio, connect the amp turn on wire to the blue/white wire on your radio.
if youre connecting your OEM radio, connect it to the ignition/accessory wire. i am assuming you have a OEM harness adapter, just follow the red wire coming out of the harness to the factory side of the plug and viola. i would also suggest using a DMM to test it just to make sure you have the right wire.
Old Jan 4, 2006 | 07:09 AM
B.C.'s Avatar
Problem solved. Just like stated above. THanks all. Car sounds great
BC
oatnet
17
Aug 20, 2004 04:57 PM
oatnet
Jun 10, 2004 02:58 PM
oatnet
Jun 7, 2004 03:00 PM
s3las
May 28, 2004 09:43 AM
my2k2s2000
Dec 26, 2003 01:33 PM
