i have a "sirius" problem
Old Feb 9, 2006 | 07:47 PM
mmitchell's Avatar
Default i have a "sirius" problem
i'm getting a very small amount of static, it's just enough for me to know it's their. it's hard to explain but i get it mostly during rap and if i'm listening to a talk show their is none at all. it seems to happen when the bass hits, and it makes it sound like my speakers are just barely busted. if i turn on my regular radio it sounds fine. i've been through three different receivers because i thought it might be the brand. and i have tried all of my frequencies and retraced the antenna to make sure there are no nots in it. i've taken it to a audio shop and they have know idea what it is. at this time i'm using the starmate unit. can someone please help me, this is making it a miserable drive to and from work. thanks
Old Feb 9, 2006 | 09:21 PM
jasonw's Avatar
Sounds like you are using an FM modulator. You will always have static with an FM modulator.
Either that or maybe your power cable is not the proper gauge. Are you running amps? Give us a list of your components. Who did the install?
Old Feb 9, 2006 | 11:52 PM
rworne's Avatar
Their audio is digitized and compressed. It's also possible you are hearing artifacts of this process.
Old Feb 10, 2006 | 05:58 AM
S2KinVA's Avatar
I have sirius with zero issues in the sound, give us more detail on your stereo set up... HU, amps, speakers etc.
Old Feb 10, 2006 | 06:48 AM
mmitchell's Avatar
i still have the stock stereo and speakers in, i'm running the power from source just under the storage area and the antenna is on the trunk. i installed it myself but i followed the directions.
Old Feb 10, 2006 | 07:45 AM
jasonw's Avatar
So then you are using an FM modulator? That is destined to give bad results.
Old Feb 10, 2006 | 07:48 AM
S2KinVA's Avatar
ok is it static (like a radio station fading out) or is it a high pitched whirring noise?
Old Feb 10, 2006 | 09:18 AM
mmitchell's Avatar
the radio station is not fading out and it happens during the lows, bass. it sounds as if my speaker is almost busted.
Old Feb 10, 2006 | 10:01 AM
MULDER's Avatar
PLEASE ANSWER THIS QUESTION!!!: Are you using an FM modulator?
Old Feb 10, 2006 | 10:20 AM
jasonw's Avatar
