i have a "sirius" problem
Old Feb 10, 2006 | 10:44 AM
S2KinVA's Avatar
OK.... here is my final diagnosis... Turn your stereo down, between the rap and the compression of the sat signal you have probably fried the paper cone speakers in the door.
Old Feb 10, 2006 | 10:47 AM
MULDER's Avatar
Originally Posted by S2KinVA,Feb 10 2006, 02:44 PM
between the rap
Well, there is part of the problem right there.......
..... put down the Kanye and step away......
Also.... what bass in the stock speakers are you talking about? If you were trying to get bass out of a stock HU (unless its an 04/05) and stock speakers.......................................... ......................... you've blown them.
Old Feb 10, 2006 | 01:24 PM
S2KinVA's Avatar
To sorta quote Johns (Darkknight) sig.... "Pumping lots of bass to a factory speaker is like stuffing a basketball into a pigeon
Old Feb 10, 2006 | 07:31 PM
mmitchell's Avatar
yes it is a fm modulator, and kanye is an idiot. the only reason i used rap is because that is where it is the most, it's not as bad listening to system or the deftones. so the lows are stronger through the modulator than the regular radio? i don't think there busted because it doesn't happen using the regular radio. but i could be wrong, it has happened before. i do need to upgrade the speakers anyway, i just hope it works. thanks for all of the advice, i do understand how hard it is to fix something without never seeing/ hearing it..
Old Feb 11, 2006 | 10:45 AM
revhi's Avatar
Which Sirius unit do you have? Sirius units have weak FM mods and do not transmit in stereo. Get an Aux in, but chances are you might still get engine noise.
00SType
Nov 12, 2010 10:46 AM
h2oman104
Jan 2, 2010 12:15 PM
S2Krzy03
Oct 27, 2009 05:39 PM
PAKS2K
Jan 23, 2005 07:37 PM
Tedow
May 22, 2004 02:26 PM
