Install help!
Old Feb 2, 2006 | 11:23 AM
toeknee's Avatar
Default Install help!
I just recently joined the dash cutting crew and installed an Alpine TME-580 in my dash. I have most of the wires set up except for the brake and hand brake wire. I was told that the two had to be hooked up inorder to play video at a stand still. Is there any way I can bypass this so I can have the video/ navigation playing while I am driving. After searching online I found a little black box on ebay (PAC tr7) that people swear that worked in bypassing Alpine safety feature. Will this work with a stock headunit? Is there any other way of bypassing this feature without getting the black box? Also, since I bought the monitor used..what is the process of getting the screen to play (i heard something about holding the break and then pulling up and down on the e-brake, not to sure though) Any help is appreciated.
p.s. before anyone asks, I will be getting a headunit soon just looking for a temporary fix.
Old Feb 2, 2006 | 11:28 AM
NFRs2000NYC's Avatar
I dont have experience to that particular model, but if you ground them, you should have done it. The unit looks for the ebrake to activated, so its either a ground, or a 12V constant. On Pioneers, its just a ground. Wait till a few more people answer, and youll know 100%.
Old Feb 2, 2006 | 11:31 AM
toeknee's Avatar
i'll give that a try..so brake wire to a 12v and e-brake to ground ? I just tried to run both wires to a 12v and that was no luck.
Old Feb 2, 2006 | 11:51 AM
Try to ground them both.....
Old Feb 2, 2006 | 12:25 PM
Matts2k's Avatar
Yes grounding usually works. I know for a fact pioneers work like that, but im pretty sure alpine would be the same way.
Old Feb 2, 2006 | 12:53 PM
darkknight1999's Avatar
Ground them. I have that screen and If I remember correctly I just grounded them...
Old Feb 2, 2006 | 02:15 PM
toeknee's Avatar
i will give it a try when i get off of work... working from 3 to 10:30 sucks
Old Feb 3, 2006 | 05:01 AM
toeknee's Avatar
so i grounded the both of them and it seems to not be working...any other ideas guys?
Old Feb 4, 2006 | 09:31 AM
SCA S2K's Avatar
The foot brake wire should be hooked up to ignition 12v.
e-brake wire should be hooked up to a good ground source.
hope this helps.
some of the first alpine models had a goofy sequence of brake on, brake off,
e brake on, that you had to do to get them to display video while you were driving.
i would say check the manual if you have it and make sure this is not the situation.
if for some reason it is you can still bypass it with a momentary and toggle switch.
if it turns out that is the case i have the stuff to do it and can send you a diagram.
Erik,
Sounds Car Audio
Old Feb 4, 2006 | 10:19 AM
I looked it up. The above is correct
