Installed my 9856 + Modifry...only interrupt works
Old Jan 25, 2007 | 09:55 AM
LS Boy's Avatar
Originally Posted by modifry,Jan 24 2007, 08:22 PM
9856 is IR-only, right? So I'd look for a problem with the DCI IR emitter or it's wire.
You can use a digital camera to see if the emitter is working - watch your camera's LCD screen while it's pointed at the "business" end of the IR emitter. When you send a command (other than mute) you should see the IR emitter light up.
thanks for the tip bob!
i tried it this morning coz its been bothering the crap out of me lol.
anyways, emitter works and when i press the mode/ch on the dash, the emitter lights up. but does nothing.
but before i try to cut the wirings again, and reconnect it......what else should i look for?
Old Jan 25, 2007 | 10:24 AM
oth's Avatar
oth
do you have the original alpine remote, and does it work?
Old Jan 25, 2007 | 03:24 PM
LS Boy's Avatar
for some reason, the 9856 does NOT come with remote :/
Old Jan 25, 2007 | 03:29 PM
Rich04's Avatar
EDIT
Old Jan 25, 2007 | 04:04 PM
LS Boy's Avatar
Originally Posted by Rich04,Jan 25 2007, 04:29 PM
EDIT
i wonder if ANY alpine remote would work?
Old Jan 25, 2007 | 04:30 PM
Rich04's Avatar
Thats along the lines of what I was gonna suggest, but I didn't think they worked that way
Old Jan 25, 2007 | 04:34 PM
Rich04's Avatar
Woah, the manual says the only remote that works with it is RUE-4190
http://www.crutchfield.com/S-amn8nw1TNN1/c...50&I=500RUE4190
That's not a standard remote...maybe the standard alpine IR isn't used such as with the lower end HU's and its a diff signal? much like how diff brands use diff codes? Modifry can u elaborate if this is possible?
Old Jan 25, 2007 | 04:46 PM
Rich04's Avatar
From another thread
I just completed my install of this head unit along with the IR DCI and an IPOD cable. It was a piece of cake to install, and everything works perfectly. However you have to mount the DCI's IR transmitter a bit further out because of the location of the receiver on the faceplate.
Try pulling the IR out like 2 inches from the HU and see if it works, maybe the HU just isnt picking up the signal
Old Jan 25, 2007 | 07:46 PM
LS Boy's Avatar
i tihnk its picking up signal coz it lights up when i press the dash
Old Jan 26, 2007 | 06:02 AM
Rich04's Avatar
The HU lights up or the IR? If the IR does and theres no indication that the HU is receiving it, try what I wrote above. Pull the IR out away from the edge of the HU and bring it out like 1-2 inches, just so you know for sure that the HU can see the IR emitter
Not to thread jack, but I found an odd quirk with mine again. It only works after the car has been started for a few minutes, and thats only intermittant. For instance, it worked yesterday at 8am and 11pm...but this morning on the way to work, again, all the controls were not functional. Then I parked at work and tried all the buttons and only the volume down button would work, none of the rest I tried the phone cam test and saw the same thing...only the volume down was emitting
