Installed my 9856 + Modifry...only interrupt works
Old Jan 26, 2007 | 09:29 AM
  #21
oth's Avatar
oth
the dash buttons (other than mute) work by providing different
levels of resistance on the dash wire when pushed. (see:
http://www.modifry.com/products/dci/tech.htm)
If only one button works (consistently) , it could be:
a) dash switch resistance out-of-spec
b) extra resistance in the wiring
c) bad DCI
I would suspect (b) if volume down produced an IR signal
but did not necessarily lower the volume, but otherwise I'd
guess temperature-dependent problems, most likely in the DCI.
If you have a multimeter, Modifry tells you how to check
the resistance on the above webpage.
Old Jan 26, 2007 | 09:59 AM
  #22
Rich04's Avatar
c) bad DCI
I think I have one laying around somewhere still, I'll have to check it out. It's just so weird that one minute it will work 100%, then after that no function or one button. Could be over heating, b/c I wouldn't suspect a faulty DCI if it actually DID work one sec then the next it had limited function...especially if it's going back and forth
Old Jan 26, 2007 | 10:04 AM
  #23
oth's Avatar
oth
intermittent problems usually are either bad wiring or something
like a cracked circuit board in the dash switch module. bumps
and temp swings cause things to get better/worse
Old Jan 26, 2007 | 10:26 AM
  #24
Rich04's Avatar
Well behind my HU is a rats nest still...I'll take some time this weekend and tidy up all the wiring and see how things turn out. If anything I'll go get a new DCI if all else fails
Old Jan 27, 2007 | 03:16 AM
  #25
LS Boy's Avatar
everything works great now.
the IR was too far/not visible enough to my HU IR.... moved the DCI IR to right side and works great now!
thanks for everyones help
rail157
May 19, 2009 02:39 PM
MC_BLADE
Oct 31, 2007 06:29 AM
cw_huntington
May 23, 2006 07:57 AM
mr_grand_prix
Aug 23, 2005 05:55 PM
kawshon
Aug 16, 2004 06:14 PM
